Thread: "Rinse" setting on Jacuzzi sand filter with 7 function dial
    Hello,
    I have an older (early 2000's) jacuzzi sand filter with the DVK-7 multi port valve on top.
    After backwashing the filter discharges some ultra fine crud back into the pool when it is set to filter again - it not a big deal, just annoying. I have read elsewhere here that the "rinse" feature on some valve setups can be used to return some water to waste just for this reason before directing to the pool.
    does anyone know if this is case with this filter ?
    I have also read a that one can install a 3 way diverter with a waste line on the main return to the pool to accomplish this purge function.
    thanks in advance
    16 X 32 wooden frame with aluminum braces in ground pool. 3.6ft shallow end, 8.5ft deep end. 22,000 gallons. Pool constructed in 1976 in Chicago area. Mechanics: 1HP hayward super pump, Jaccuzi sand filter, Hayward SWG, and Raypak 2100 heater. No main drain (capped years ago) 3 jets, 1 skimmer. Liner replaced May 2013.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    Re: "Rinse" setting on Jacuzzi sand filter with 7 function dial
    If you click on the picture on this page it will zoom in so you can read part of the label. It does show one of the setting is rinse. If the label is too worn to read you can order a new valve cover.
    Love TFP? Become a
    TFP Supporter!
    Jun 2013
    East TN
    309
    I thought I was the only one with Jacuzzi parts. I think they went out of business a few years ago but not 100% sure. I couldnt find any parts when I looked a couple years ago.
    Filter-Water goes in filter the regular way and through the return fitting.
    Backwash-Water goes in filter backwards to backwash and through the backwash fitting.
    Rinse-Water goes in fiter the regular way and through the backwash fitting. I always rinse for several seconds after backwash.
    Drain-Water bypasses filter and throught the backwash fitting.
    There are a couple more settings that I have no idea what they do. I cant even remember the names on it. Dont need them anyway. I think they something to do with a spa.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
