Just registered because I have a problem. I'll state it here and you can tell me where to go. I mean where I should really post it. Had a tough time with the pool. Wasn't making chlorine. Salt cell was old so I replaced it. When I say old I mean 8 years. I have a Goldline aqua rite. Then no flow light solid, change the flow switch, why they originally installed it on the bottom of the T, 3 inches above the ground is beyond me. Super chlorinate, shock, vacuum, repeat. Now the pool is crystal clear, good water flow, Chems are perfect and the salt generator says it is generating. No Chlorine at all when it is tested. Still running it 24hrs a day at 85%.
Raebrek!!!
Raebrek!!!
