Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Well, my pool IS a lovely shade of green! Please help!
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    About a month ago, my pool started to look bad. Took water to the pool place, and was sent home with 50lbs of baking soda, a couple of other pH manipulators and 3 bags of the rapid dissolving granular chlorine. A week later, it looked worse. I went back and was given more of the same, plus something for metals and sparkle. At this point I've added about 20 bags of that chlorine within 2 weeks. And now, over $250 later, it's still green. Strangely, there is no algae on the sides? but the water is an emerald green; not clear, not terribly cloudy, but thick looking. So today, I went and had them test my water, just to see the levels. Yes, I know I need a good kit, but I don't have one and cant get one right now. SO, this is what i have:
    IG
    136000 gallons
    sand filter (which seems fine) dont have the model # with me, but it's the biggest round one
    vinyl liner
    it was installed almost 20 yrs ago
    Today's readings:
    FC - 0
    PH -7.7
    TA - 121
    CH - 290
    CYA - 75
    Also, High Phosphorus (which would cost $100 for a fix)
    So, from what I'm reading, the phosphorus stuff is hooey? and I should just slam it?? (which i cant properly do without a kit)
    I've already put so much of that granular rapid dissolving stuff in it's ridiculous!
    What's the deal? Can somebody help me?? Thanks ahead!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Well, my pool IS a lovely shade of green! Please help!
    Welcome to TFP Tricia!
    I swear 3/4 of the people who are on this forum could tell that exact same story, word for word. You've actually gotten by fairly cheaply so far. Fortunately, you've found the place to to get your solution.
    You already know the solution. SLAM the pool. The bad news is you need a test kit. The good news is that it will cost much less than what you've spent so far, and if you order from TFTestkits.net you can have it in just a few days.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Hi Tricia,
    So you know you have already answered your own questions. You do need a test kit but I understand. For your own benefit, get one as soon as you can because it's difficult to offer advice without accurate test results.
    Phosphates are hooey in the sense of who cares if you have algae food present if you don't have algae. So that's where you need to be, without algae.
    First and foremost, I would stop adding stuff based on the recommendations of the pool store results and advice. I do believe they have proven that their way doesn't work. Save your $$$. Next, I would devise a plan to get a kit.
    In the mean time, read up in Pool School and learn all you can about your pool and water chemistry. A SLAM is indicated if your water isn't clear in the presence of CC and overnight chlorine loss. Then I would learn to use Pool Math to find out what and how much chlorine etc to add. Liquid chlorine is your friend. Stay away from solid forms. You can also get some MA to adjust your pH down to about 7.2ish.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    So am I doing it right in that I should add 30 gallons of 6% bleach with that cya?? Do I put it in all at once? on a jet??
    Quote Originally Posted by JohnT View Post
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    Is one hundred thirty six thousand gallons correct? Got any pool dimensions and depths to go with that?
    SW Indiana
    9,199
    Are you sure your pool is 136,000 gallons? That's about 7 times as big as most residential pools.
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    omg, sorry, 36,000
    that'd be even more depressing to have 100k more gallons of the green stuff!!!
    It's 20'x40', 8' deep on the deep end and 4' on the other. i used the poolmath page which is awesome, btw!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Then work pool math based on your available numbers until you get your good kit. Just be aware that your working blind with inaccuracy. Pour bleach slowly in front of a return with pumps running 24/7.
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    So 30 gallons of bleach, poured in slowly, all at once, over a jet, isn't crazy!? That's normal for a SLAM?
    Just seems like a lot to me b/c i've never SEEN that much bleach. But PoolMath tells me 2085oz.
    38,475
    That many oz is not 30 gallons.
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    Ok, so obviously I'm new, and don't cook either!
    So that makes 16 gallons then, poured in slowly, all at once over a jet. and leave it running til it's clear.
    Have yall got me kinda straight now!??
    Thanks so much!!!
    38,475
    Are you sure you have 6% bleach and not 8.25% bleach? What are the actual ounces in the bottle?
    Yes, 16 gallons or 6% are required to initially get you to shock level. Then you need to be testing at least twice a day and raising it back up to shock level ... that is the maintain portion of the ShockLevelAndMAINTAIN Process
    How are you going to test the FC level that high? You have a test kit yet?
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    Yea! Got the kit ordered today! So I should have it in time to do this right! Thanks everyone for all your help!
    36000 Gallon, IG, biggest Hayward sand filter, vinyl liner, Polaris vacuum
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    Ok so I have begun the Slamming process. It has been 24 hours and I see practically no change in appearance. FC level is holding ok I think for this soon : 7.5 this morning, with target at 12. I am checking and adding every 3-4 hours. Is this normal for appearance to be slow to improve?
    38,475
    How long did it take for your pool to get to this condition? Why would you expect it to instantly be fixed?
    Post up a full set of test results before you continue.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by Tricia1969 View Post
    You stated your CYA was 75 in the first post. I may have overlooked it, but I don't see anything stating you lowered it. If not, it doesn't seem like 12 would be the correct shock target for your CYA.
    If you start pretty green, it's going to take more than a day or two to clear it. Especially if you aren't dosing soon enough to keep it over the correct level for your CYA. It may help to read a few of others' threads about clearing algae, it gives you a good idea of what to expect. Good luck, it CAN be done!
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    I drained and refilled. Current cya is 30
    Oct 2013
    Chapin, SC
    1,141
    My pool math says your shock level is 29 which would require an initial bleach addition of 1683 ozs of 8.25% or 2314 of 6% if that's really correct. 12 is correct for shock then. Which is 896 oz of 6%
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Aug 2010
    Dallas, TX
    4,052
    FYI, 2-3 weeks isn't uncommon. 3 weeks isn't the norm, but it does happen. It will probably take at least a week.
    Are you sure your pool is 136,000 gallons? That would be a really big pool.
  20. Back To Top    #20
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    I corrected that, 36000 thx
    36000 G, IG, sand, vinyl
