Results 1 to 15 of 15
Thread: What happens when you run out of money for pool chemicals
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    It's been awhile since I have posted. Been going through some things. Who isn't though, right? lol Anyway, I got separated in December and divorced in June. I got to keep the house, the kid, and the pool. Sadly, she got my flat screen TV. Anyway... been getting used to the single income lifestyle and making some adjustments. So, I ran out of money for bleach a few weeks ago and got algae. At that point I decided to let it run wild until I got my budget straight and built up a good bleach supply to regain control and maintain it going forward on my new budget. I have 25 bottles of bleach now and will be getting another 25 in a few days. So, is this thread useless without pics? For your viewing pleasure...
    Before:
    Now:
    Welcome to my cleanup thread. My daughter is vacuuming it right now. After that it will get a good daily scrubbing and then I will bring the chlorine up to shock levels and maintain it until its clean. Not my first algae outbreak but definitely the worst. I got one a few year ago so I know how to deal with it, this is more or less just a cool thing to watch over time, the cleanup.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Re: What happens when you run out of money for pool chemicals
    You could use a cover if you need to put the pool on hold for a while. That would keep it clean and algae free.
    Support the site
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I thought about that but figured since it was out of chlorine it would still grow. I have a winter cover but I did not think that would stop the growth without getting the chlorine level up.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    If there's not a whole bunch of debris in there, it ought to go pretty quick. If you can set the filter to recirculate, you can get a good kill on it, then vacuum the crud to waste, and then finish the job normally.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Sorry for the disruptions in your life. Sometimes letting the pool go is the right answer.
    At least you know the pool cleanup isn't as big a mess as it seems. Good luck with it!
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Richard, That is exactly what I did. It just so happens that mere days before I let it go we vacuumed it. Most of what you see is just algae. We vacuumed yesterday but rustled up enough algae to make the bottom impossible to see. I ran the FC up to 20PPM and today almost 20 hours later it was back down to 1.5ppm. I just shocked it again. It does look better today. The water is still murky but it has a blueish white tinge to it. You can see the missed spots on the bottom from the vacuuming. My daughter is brushing it all up real good right now. A couple of pics. Its still got a long way to go. But I think by tomorrow I should be able to get a good scrub on the entire pool without losing visibility.
    Jul 2014
    Medina, Ohio
    55
    What is the break-even point between the number of gallons of bleach you'd need versus the cost of 23K gallons of new, clean water? Seems around the same amount of time either way....it's gonna be at least a few days before you can be swimming again if you drain and fill versus the cleanup and SLAM process.
    Seems like with all the threads I read about people needing to spend massive amounts of time and lots of money on bleach, no one asks the question or even considers a pool drain and refill. I know to fill my 17000+ gallon pool, I spent about $100 extra on my water bill......do you think you will exceed that in bottles of bleach?
    17,100 gallon, 27' round Wine Barrel, Hayward Matrix 1.5HP 2-speed Pump, Hayward Pro Series 24" Sand Filter, Hayward Skimmer and Returns, TF100 test kit......and lots of labor!
    Aug 2010
    Dallas, TX
    4,052
    To answer one of your questions, I remember my days like that. It may not be an option for you, but I got a roommate during the tough times. At the time I was 38 years old, and that might seem odd, but you do what you gotta do, know what I mean?
    Richard320's Avatar
    Jan 2010
    18,983
    Quote Originally Posted by Augie56 View Post
    You haven't read enough, then. Most of the swamp threads come in May or June, and that option has been suggested.
    But a drain isn't always as simple as you think. If the pool has a vinyl liner, it shouldn't be completely emptied. The liner can wrinkle or shift. Above ground pools can have a wall bow inwards. Intex pools can shift off their supports. In ground pools can float up and break pipes if the water table is high. You have to leave some water in the pool. So there's always going to be at least a foot of green water to deal with, which will require lots of bleach anyway. Then there's the expense of adding new CYA. And if the water is high in TA, gallons of acid to lower that again.
    And for a good many of us, operating under water restrictions, a drain isn't possible.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I have an update.
    The water was mostly clear today. I have been brushing mostly from the outside of the pool until it cleared up enough to see the bottom. I did an OCLT and lost no PPM. It seems kind of odd that it would lose none when the water was still a little cloudy and there was still brown spots on the bottom that were missed. I checked it again tonight after sundown and its at 13.5 ppm. Will check again in the AM.
    I do have an issue. It appears the algae may have become "attached" to my liner. There are brown stains on the liner that feel rough and the brush does not clean them no matter how hard I try. Its mostly in corners and hard to reach places. Is that normal? I would post a pic but it got cloudy on me today after I got in and gave it a real good scrubbing. There are even brown stains on the stairs. The "green" has disappeared completely. It's like all the algae is dead and turned brown. Most of the brown spot just clouded up and left clean liner where there was once brown.
    Augie56, Richard is correct. A water change on mine (while possible) is not advised without extensive prep work. It is buried about 30" in the ground and the liner would indeed become an issue. I do not know about the walls but its not a chance I am willing to take. But, The bleach so far has cost about $120 but I still have 9 of the 47 bottles left. I think the fill cost me about $75. It holds 26300 gallons.
    RobbieH,
    I thought about that but for what I do for a living, its not a good idea. I would need someone I trust implicitly and even then, the stakes are high and possibly deadly for me and my daughter if I make a bad choice.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Another update. OCLT passed with 0 loss once again. I still have these though and don't know how to get rid of them. Anyone have any idea what it is or how to get rid of them?
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by Glock View Post
    RobbieH,
    Both my roomies (one at a time, not two at the same time) were extremely good friends, not strangers.
    Smykowski's Avatar
    Sep 2011
    3,065
    Need to determine if that substance is metal staining or organic staining. Any powder/pucks laying around?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Quote Originally Posted by Smykowski View Post
    No I am straight bleach. I have thought about adding a floater though. The stained parts have a rough texture though. The water is pretty clear right now and if is even better tomorrow I am going to get back in and try to remove some of it again.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I'd you have a vitamin C pill, drop one on a stain. If it clears the spot, it's metals.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
