Thread: Trying to ID a Hayward multi port valve
    Aug 2014
    Ridgeway, SC
    2
    First post... I searched, but didn't come up with anything.
    I have a large pool (~40,000 gallons). Everything was here when we bought the house and it's been quite the learning experience!
    My Hayward multi port valve has SPX-710X32 on it and has a cracked housing. I am trying to figure out exactly what I have. The piping going to the pump is all 1.5", but the connections to the S-240 filter are 2". From whatnot can find on the Internet, the 710X32 has all 1.5" connections, and the 715X32 has all 2" connections.
    Anyone have any insight here? Thanks for any help!
    Anthony
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Trying to ID a Hayward multi port valve
    Quote Originally Posted by Wave View Post
    Anthony
    You should directly replace with the same part number. The only difference between the two is the adapter size to the return and pump lines. If you have 1.5" going to pump (I am assuming it's 1.5" to returns as well unless there is a reducing fitting) that's what's important.
    Isolated Spa - 345 Gallons
    Aug 2014
    Ridgeway, SC
    2
    Thanks Joel! Are you saying that's the 710x32 and the 715x32 both have 2" fittings to the filter? That would make it simple! I wasn't sure that the dial face of the multiport was original which is where the model # is.
    Feb 2014
    Central Minnesota
    5,080
    Hayward valves are typically the same size going to the filter within the same product line. You have an S240, which I believe they do not sell anymore, just the S200 so it makes it a little murky on which to go with but you can use either valve with either the S200 or S240, which leads me to believe the fitting to the sand filter would have to be the same. When I found older manuals for the S240, it lists both valves as compatible so if you have 1.5" lines to return and pump, the SPX0710X32 is the way to go.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum
    You can always call or write Hayward too. https://www.hayward-pool.com/shop/Pr...51_12152_-1___
    S200 manual with parts diagrams : https://www.hayward-pool.com/pdf/manuals/S200.pdf
    Apparently the S200 and S240 share parts and the difference is size and sand capacity.
    Solar Blanket, Well Water, Borax Added. 68
