Thread: Heat exchanger in a Raypac heater
    Jul 2014
    Middletown, MD
    21
    Does anyone know where the heat exchanger is located in a Raypac heater? I got a code saying that the heat rollout safety switch tripped. I looked it up and it says that the heat exhanger is clogged. \
    Does anyone have a clue?
    35,000 gal. IG plaster pool and spa, Hayward Pro S31-T2 sand filter, Paramount PCC2000 in-floor cleaner, auto chlorinator (not using), old Purex hi-performance pump
    TF100 and TF1005 test kits, speed spinner
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Heat exchanger in a Raypac heater
    If you take off the center top lid which usually just needs to be shifted slightly that will expose the top of the exchanger. Try vaccuming it off with a shop vac. for starters. I had a pool company clean out the burners the year before. That worked for me on my last one but eventually I started getting issues every year so just bought a new one. I think my last one lasted about 12 years in the Midwest not covered in the winter.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2014
    Middletown, MD
    21
    Thanks, wjr75 for the information about the heat exchanger. The heat exchanger as been the home for a mouse nest, then once we got rid of the nest, a black snake moved in, probably looking for more mice. So now I bang on the heater before I open the lid just to let anything living in there know I'm coming. I think my dh found out why the heater won't turn on. The flame rollout safety fuse blew. It probably blew because there was still some stuff on the heat exchanger. I found it online at Pool Supply Unlimited, but the shipping charge was almost as much as the part. Does anyone know anything about this company?
