Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: First Test Results - Now what?
    Aug 2014
    East Northport, NY
    155
    FC - 4 (I took all the Chlorine tabs out this AM and added 3 gallons of Bleach) I assume I should add more tomorrow?
    CC - 1
    TA - 140
    PH - 7.2
    CYA - 80
    CH - 325
    I am going to keep a log of these but would love guidance since I am still trying to figure out pool math. I am also purchasing the RC52 Auto Pilot tomorrow.
    Thanks and looking forward to hearing from you!!!!!!!!!!!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Feb 2012
    Phoenix, AZ
    728
    Re: First Test Results - Now what?
    Hello Amanda! What kind of test kit are you using for those results? We recommend a FAS-DPD test kit (like the TF-100 by TFTestKits or Taylor K-2006). They are much more reliable than test strips.
    For the most part, your levels look good! However, with a CYA of 80, you want to keep your FC at a minimum of 6 (ideally 9). Here is the CYA-FC Chart: http://www.troublefreepool.com/conte...art-slam-shock
    How does the water look? Your CYA is a bit high (for a non-SWG) pool, but not crazy high like some people get with tabs.
    If you have not already, I suggest you familiarize yourself with Pool School (especially the ABCs of Water Chemistry).
    Aug 2014
    East Northport, NY
    155
    I should have mentioned I used the TF100 for the tests which I received today. So tomorrow, do I add another gallon of bleach? Pool has some green algae and is not crystal clear, I can see the drain but it isn't clear.
    TF-100 Test Kit
    Aquabot Bravo
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by Amanda14 View Post
    OK well that's great you have a TF-100! If you have algae, you are going to need to SLAM your pool.
    Here is the link to article with instructions:
    http://www.troublefreepool.com/conte...ntain-shocking
    Here is a video explaining the process: (which I believe will be added to the forum soon)
    EDIT - See below for video
    Check those out and report back if you have any questions!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,082
    Quote Originally Posted by blakej View Post
    Here's the YouTube video explaining the SLAM process.
    Lowering your CYA level to around 40 will greatly help you while SLAMMING your pool. The ABC's of Pool Water will further explain why.
    Feb 2012
    Phoenix, AZ
    728
    Thanks for the video embed Leebo! I mistakenly copied the same link twice (to the article)
    Aug 2014
    East Northport, NY
    155
    The following day test - overcast
    FC - 1
    CC - 1
    TA - 170
    PH - 7.2
    CYA - 80
    CH - 300
    Backwashed after and scrubbed down the little bit of Algae I saw. I suppose the first thing I need to do is to add much more bleach since the level isn't rising as much as I would like. I know you can swim after 30 minutes but what about adding other chemicals? I will add bleach later tonight but then can I add baking soda to raise the PH after that, like an hour after? I really don't want to empty a portion of my pool yet, but will when I cover it in a few weeks.
    TF-100 Test Kit
    Aquabot Bravo
    Mar 2014
    Las Vegas
    288
    Since you are dealing with Algae, I would not raise your pH. From what I understand, chlorine is more effective at a lower pH. Wait until after the SLAM to get your pH in line.
    Also, don't forget to check behind your light for Algae. It likes to hide behind the light.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    I wouldn't touch the pH yet since the advice is to SLAM.
    That being said, your pH would tend to rise on its own with your TA level.
    In any case, the recommendation is to raise pH with washing soda (soda ash/sodium carbonate) rather than baking soda (sodium bicarbonate/sodium hydrogen carbonate).
    I would recommend you read ABCs of pool water chemistry and recommended pool chemicals if you haven't already done so.
    Aug 2014
    East Northport, NY
    155
    Thanks. Will begin to slam starting this evening
    TF-100 Test Kit
    Aquabot Bravo
    Jul 2011
    Eastern Ohio
    7,082
    Quote Originally Posted by jmbradwell View Post
    This is a 1/2 true statement. FC is more effective at low pH levels when CYA is not present. Once you add stabilizer to the water, then the chlorine all works the same. The reason we suggest lowering your pH level to 7.2 before a SLAM is due to the testing of pH. Any FC level of 10 will result in a false pH. By lowering your pH level to 7.2 you will give it some wiggle room to increase before running into any major problems.
    While SLAMMING with a CYA level of 80 can be done, I would REALLY suggest once again look into lowering the level. Even draining some to lower the level down to 60ppm will help you out in the long run. By lowering the CYA from 80 to 60 your FC level for your SLAM goes from 31 down to 24. Much easier to maintain in the long run.
    May 2013
    Fort Lauderdale, FL
    423
    Glad you got your test kit! You have your full numbers, so you can stop running the full battery of tests daily (you'll burn through your kit!). You're going to SLAM so Ph will not be reliable with FC over 10. For now just worry about the chlorine level using your drop test with the powder, not the yellow scale. You're going to need a LOT of bleach. Get a couple of cases. For CYA of 80, your SLAM level is 31 minimum, it can't go below that until you're done. Re-read how to do the SLAM in pool school. You need to raise FC to over 31, run pump 24/7, and brush the pool a lot. You need to maintain the FC over 31, which is going to drop every few hours at first. Every minute below 31, algae will start to will the battle and increase the time of your SLAM process. I would not have anyone swim in until SLAM is over. SLAM isn't over until you have crystal clear water, CC is below .5, and you pass the OCLT. All three.
    After your pool is fixed, I typically ran a full test every week and checedk ph/FC daily. After the SWG is in, you can even stretch how often you do the FC check once you get it dialed in.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Aug 2014
    East Northport, NY
    155
    Really helpful thanks. I am going to walmart after work and going to buy 4/5 cases of bleach and some borax to have on hand for ph when required. I am buying the autopilot tonight but regardless of that I am going to start the slam but before I do, I am going to take out some water per the advice above which I get and understand. Every little bit I take out will help. Funny you mention about the kit- I was thinking the same thing about running through it.
    Aug 2014
    East Northport, NY
    155
    Also, this may sound ridiculous but I am going to ask- if I remove water via waste and refill with a hose is there a certain amount of time I should wait to check cya? Because for now all I am going to check is cya to see what I have on my hands for slam.
    Oct 2013
    Chapin, SC
    1,141
    Just run your pump for a while then do the CYA test.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2013
    Fort Lauderdale, FL
    423
    No waiting required. You only need to wait on CYA after you add some, it can take a week to register the whole amount.
    Personally, I wouldn't worry too much about dumping water right now. You're going to go to salt, so 80 will fine for that. And it will slowly drop as it rains and you backwash, etc. I would concentrate on the slam and it's going to need a lot of bleach. Take lots of pics, we love seeing pools go from green to cloudy to crystal clear!
    Side note- when you hit "reply" there a little box you can check for "show signature", that will help other members post to your threads.
    Oct 2013
    Chapin, SC
    1,141
    ^ concur with just using more bleach for now if you're going to a SWG anyhow. Doesn't make any sense to remove cya to just have to add it again.
    Aug 2014
    East Northport, NY
    155
    I am doing quick replies from my phone while at work and I don't see te ability to check a box about my signature - sorry about that! One thing I should mention - my pool isn't cloudy or green, I can see the drain and I have some green spots that I have been brushing. This isn't a swamp scenario. I still intend to slam but just wanted to point out my scenario. I have one other question - I have a solar blanket actually I am throwing one out and buying a new one (I typically get them from in the swim and I go for the 16 mil version) so any concerns as it relates to chemicals with swg or without when using a blanket? I would probably use it next summer not this one since I am fighting this other chemical battle.
    Aug 2014
    East Northport, NY
    155
    All set to do SLAM but its supposed to rain tonight. Wondering if I should hold off until there is no rain. Thoughts?
    TF-100 Test Kit
    Aquabot Bravo
  20. Back To Top    #20
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Algae grows in the rain so you can kill it in the rain.
    SLAM away.
    It may be a little uncomfortable for you, but it will make your pool fees so much better!!
    Support the site
