Thread: Help: sand or dirt or debri back in pool afrter vacuuming
    Aug 2014
    New Harmony, Indiana
    1
    Split by moderator from HERE. Please start a new thread to ask your own questions and not "hijack" a 4 year old thread. You will get better and more personalized responses. Thanks, jblizzle
    I'm struggling with a similar problem. My pool looks great other than debris in the bottom....just in the collection areas. When I go to vacuum it I see it coming back in the pool. I've tried to vacuum on 'waste' and it seemed to help a little. This process is maddening....I hear laterals and multiports mentioned......don't know what those are. I guess I need to get to where I know more about my pool system. Any help would be greatly appreciated.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Help: sand or dirt or debri back in pool afrter vacuuming
    Welcome to TFP!
    The fact that you have a "waste" setting indicates that you have either a sand filter or a DE filter.
    Are there any labels which can help to identify the equipment that you have? You could take pictures of your set up and post them here, we would then be able to assist you better.
    How to post photos
    Mar 2014
    Las Vegas
    288
    Also add your pool information to your signature. It helps us when answering questions.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Sep 2012
    Gardiner, ME
    165
    I vacuum to waste after a big rain storm and I need to drain water off my pool. Usually once a month
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
    30,413
    Can you post a set of current test results? That's the first step. Also a pic of your water is often helpful
