Thread: Borate Drop Test - Failed
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    I tried the Borate drop test today. I had ordered the S-0009 and S-0010 from Amazon to use in conjunction with my Taylor K-2006. So I got to step 3 where you add 5 drops of the S-0009 Bromothymol Blue. The sample should turn yellow. Didn't happen. So then, you continue adding R-0009 drop wise while capping and mixing until you achieve yellow. Never happened. I used 1/4 of a bottle of R-0009 and never achieved yellow. Test discontinued.
    Any ideas as to why my sample didn't turn yellow. I used 2 drops of R-0007 in step 1 and 5 drops of R-0009 in step 2 as per instructions.
    Appreciate any advice on what I should do differently.
    11,600 gallon plaster salt pool & spa, IC20 SWG, IntelliPH, cartridge filter, 2.7HP IntelliFlo Variable Speed Pump, Gas Heater, Easy Touch System w/remote, 8 roof mounted solar panels
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borate Drop Test - Failed
    Are these the instructions you're following?
    http://piscines-apollo.com/docs/ap_borates_en_ins.pdf
    Chem Geek posted a lot of info here: http://www.troublefreepool.com/threa...l=1#post280115
    http://www.troublefreepool.com/threa...-vs-test-strip
    I know it doesn't answer the exact question but may give you an idea of what's not happening.
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    Yep, those were the instructions I followed. I also did some pre-reading from this site and found at least one other member had the same issue ie. no detectable change to yellow in step 3. Didn't see any resolution posted. One of my reagents in my Taylor kit is old and I'm hoping that replacing it will generate the expected results as outlined in the instruction guide. I've been using the recommended strips; however, recently had some significant PH bounce and suspected my borate level had dropped (lots of rain & drain) yet the test strips weren't giving that indication. Looked like my borate level was around 30ppm. Had a second set of eyes looking as well. So after doing some research, I decided to order the two additional reagents and try the piscines-apollo instructions, since I couldn't get their kit. I'll post back my results after purchasing a fresh reagent and trying the test again next week.
    Mar 2007
    San Rafael, CA USA
    12,082
    Bromothymol Blue is a pH indicator dye. If it doesn't have ANY color when you add it, then it's not working and perhaps the dye is too weak/diluted. Is it even colored in concentrated form? The dye is yellow below pH 6.0 and blue above pH 7.6. Try adding it to some tap water. If it doesn't color the water even with a small sample size then you've got a bad reagent.
