Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: New pool with the ever popular green water syndrome...
    Jun 2014
    Lake Jackson, Texas
    133
    I'm going to re-read the pool school section but yesterday the builder shocked the pool and added the stabilizer and everything looked pretty clear by the end of the day. This morning I woke up to do my brushing and it looked like a Dos Equis bottle.
    I took a water sample to a pool supply and everything tested great and they said the water is swimmable but could not give me an answer on the green color. Here are the test results:
    Saturation Index: .27
    Water Color: None
    Water Clarity: Clear
    Free Chlorine: 5.3 ppm
    Combined: 0
    pH - 7.8 (I added one pint of acid)
    Hardness - 180 ppm
    Alkalinity (w/stabilizer correction) - 147 ppm
    Cyanuric acid - 10 ppm
    Copper - 0 ppm
    Iron - 0 ppm
    TDS - 600 ppm
    Pool was filled with well water and originally had .22 on the iron but the metal out stuff took that away. Chlorine is high from the shock I suspect. 8 lbs. of stabilizer was also added yesterday so I suspect that is probably still dissolving (didn't look in skimmer before typing this up).
    Thanks!
    25K gal FF; QuartzScapes Barbados Blue; ColorLogic LEDs, ProLogic PS-8, AquaPod, AquaConnect, (3) WhisperFlo 2.5HP pumps, 1HP blower, 3/4HP cleaner pump; Pentair CC 520 cartridge filter; MasterTemp 400 propane, Rainbow 320; UltraPure UV/Ozone; Polaris 280; 7' raised spa by rock waterside; (soon) 62" fire pit, (soon) ODK; 60x40 screen enclosure
    Build - here.
    38,370
    Re: New pool with the ever popular green water syndrome...
    Forget the inaccurate pool store testing and invest in one of the Recommended Test Kits.
    When was the pol filled?
    If adding chlorine makes the water turn clear green, then you must have metals in the water. You may need more sequestrant and to continually add it.
    Jun 2014
    Lake Jackson, Texas
    133
    Thanks for the quick answer and I'll order one of those test kits today! Anyone of the 5 you like more than the other or are they all pretty much the same? Pool was filled by Saturday morning and was pumping in the afternoon. Here are some pics of the water:
    Build - here.
    38,370
    The TF-100 is the best value. And the SpeedStir is a very nice add-on that makes the testing a little easier and faster.
    BTW, you get a discount on the TF-100 if you become a Become a TFP Supporter.
    May 2013
    Fort Lauderdale, FL
    423
    I'll second the TF-100. The speed-stir is nice too, worth the money. I went a summer without it and I wish I had not. While you're ordering, get a refill of R-013 for the CYA test, I ran out of that way before anything else and I hate to pay shipping on a $8 item later.
    Post your numbers and we'll get you on track. As to the 8 pounds of CYA you added- it can take a week for it to fully dissolve and register on the test.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jun 2014
    Lake Jackson, Texas
    133
    Thanks! Should I test first and then add the sequestering agent or should I run to the supply store now and get a sequestering agent to be quick to the draw? Looks like the TF-100 will need to be ordered online. I called the local pool supply and the only thing they sell are the Pentair test kits. She said that their testing is accurate but did say I could come by and get some Metal Magic and add like a 1/2 quart to be safe on not getting cloudy.
    Build - here.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Tf100 is the best value...the amount of test chemicals you get for what you pay. If your pool is green, the XL version is worth considering.
    The owner of that company is affiliated with this site, but that has no impact on my suggestion. Same chemicals as the Taylor kits, but for the cost, it's a much better value.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Jun 2014
    Lake Jackson, Texas
    133
    Quote Originally Posted by zimm View Post
    Will do. Thanks for the tip on the R-013!
    Build - here.
    May 2013
    Fort Lauderdale, FL
    423
    Oh yeah, and you can only get the TF-100 from www.tftestkits.net
    He's a big part of the forum. I don't benefit personally from recommending them- except being a happy customer for 2 years and wish to pass that along to others.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Is this a newly plastered pool? If this is, and you are high in metals you are running a major risk of devolving stains on the plaster that will not come out with normal techniques. Sequestrant is HIGHLY recommended at this point.
    Jun 2014
    Lake Jackson, Texas
    133
    Quote Originally Posted by Leebo View Post
    It is a new pool so based on what you said here, I will go get some sequestering agent right now. Thanks!
    If I do add too much of the sequestering agent and it clouds the water, is there a remedy for that?
    Build - here.
    38,370
    Make sure the ingredient you get for a sequestrant is the same as those recommended in Pool School: http://www.troublefreepool.com/conte...d-metal-stains
    Jun 2014
    Lake Jackson, Texas
    133
    Thanks. Just pulled up to the store. They have all the ones listed, I got the ProTeam Metal Magic. Speed Stirrer and TF-100 ordered, should be here Friday.
    Build - here.
    Jun 2014
    Lake Jackson, Texas
    133
    I put the whole quart of Metal Magic in. The bottle says 1 quart per 10000 gallons. I know only 1 quart was used in the beginning. I also turned on the other two pumps to maximize the distribution of the sequestrant. I'll let those two run for a little bit and then cut them back off and just let the filter pump run. Thanks for the recommendation on the TFTestkits! I spoke with them on the phone and they were extremely helpful and said the green water after adding chlorine is a tell tale sign of iron, even though the supply house showed 0 iron on the test. He also said I should probably throw a gallon of bleach in the water each evening until the test kit gets here.
    I know what the real deal is here. The water is green because my UltraPure isn't hooked up yet. I have now realized after searching ya'll are staunch supporters of it!
    Build - here.
    Jun 2014
    Lake Jackson, Texas
    133
    DOH! Not sure how I missed this sentence yesterday!
    Build - here.
    38,370
    You can still get it. Just email them with your code.
    Jun 2014
    Lake Jackson, Texas
    133
    Already been shipped and should be here tomorrow, I'm sure I'll need another one sooner or later I'd imagine...
    Update, I checked the PH again this morning with the poo poo Pentair test kit and it still showed high so I put 3/4 gallon of acid in, a little too much, it is now needing a little soda ash. Guess what, the pool cleared right up. It is not perfect yet but 95% of the green that was there is now gone. Once I get the real test kit tomorrow, I'll start using the Pool Calculator app on my phone.
    The builder did come by today and brought me 2 bottles of GLB Sequa Sol and we put one in.
    I'm going to run out to get some borax or soda ash to bring'er on back up.
    Build - here.
    May 2013
    Fort Lauderdale, FL
    423
    {Thread clean up, jblizzle} Let the Ph settle a bit before hitting it with borax. You could swing too far the other way.
    Jun 2014
    Lake Jackson, Texas
    133
    Ok, I was in a rather rotten mood earlier, my apologies, but I did just that zimm, I let it settle and decided to get the ever popular pool store to test again before adding anything just to back up what I saw (in my pool infant tester stage) before adding something else. I would think I can handle testing the pool because I have a 300 gallon reef aquarium that I do a little bit of testing in… The Pentair kit (or the pool store) was off. The acid I used earlier definitely took away the green because nothing else was added until the extra sequestrant was added. The pool did not cloud up at all from the sequestrant and before it was added I did a search on this forum and saw it mentioned in several places that it was fine to use the BLG Seaqua Sol or whatever it it.
    In any event, I'm in a much better mood now because I've been swimming for the last 3 hours.
    I forgot which brand tester they use but it was something hooked into a computer system, but regardless, my TF-100 will be here tomorrow and I will test again! Here are the results from the pool store testing:
    FC - 3.6
    TC - 3.6
    CC - 0
    pH - 7.2
    Hardness - 170
    Alk - 116
    CYA - 15
    Copper - 0
    Iron - 0
    TDS - 700
    More tests coming tomorrow with a real kit!
    Build - here.
  20. Back To Top    #20
    May 2013
    Fort Lauderdale, FL
    423
    7.2 is fine, don't bump it up. Have fun with tf100. You'll see what your cya really is. You can do the cya test multiple times once you mixed the stuff. So if your not sure when the dot disappears, pour it back and do it again.
