Thread: How Much Chlorine to Buy/Store
    FlyAU98's Avatar
    Jul 2014
    Ft. Lauderdale, Florida
    59
    After finding that Chlorine at the local pool store is cheaper than bleach for me, I'm going to pick some up today. The store does double-stamps for their buy 10 get one free card on Wednesdays, so I'll try to make Wednesday my restocking day.
    I assume I'll need to buy the 2.5 gallon bottles that are then refilled.
    I have two needs, tempered by not wanting to store more than necessary.
    1) Daily upkeep of the pool
    2) Durring Hurricane Season, be prepared to recover the pool soon after the storm. We have plenty of notice for storms, so I could go refill a couple days out.
    I was thinking of starting with 3 or 4 2.5 gallon jugs. Any suggestions?
    Yesterday's Test via TF-100:
    FC=7
    CC=0
    pH=7.3 (I think my old acid is a bit stronger than labeled, so my addition over did it)
    TA=70
    CH=275
    15.5K gal, concrete, 1HP AO Smith pump, Hayward C1200 cartridge filter, Zodiac T5 Duo auto cleaner, 8 panel solar heater controlled by Hayward Aqua Solar GL-235
    jccams's Avatar
    Dexter, MI
    95
    Re: How Much Chlorine to Buy/Store
    Not sure if this helps or not but I also get a Wednesday deal on 12.5% at a local pool store. I usually will buy 4-5 cases of 4 gallons each. I store it inside in a cool environment and have never noticed any major degradation in strength,
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The higher the % the quicker it degrades due to heat/sunlight. As a former Cooper City resident i know you get lots of both. I would base my purchases on how much you go through. Stock a two week supply, that way if you miss a Wednesday you have enough to get to the next Wednesday.
    If you are going to stick to liquid chlorine you may want to look into automating the process so that you don't have to pour it in the pool every day. Here is my Stenner pump install.
    Support the site
