Thread: 2 speed motor replacement, help with parts/decisions
    Jun 2014
    FL
    5
    Question 2 speed motor replacement, help with parts/decisions
    Hi,
    I have a Pentair Superflo 1hp (340038) pump, with a Clean and Clear CC100 filter. The pool is probably about 15,000gal. 1 1/2" pipes, a DIY solar on the ground, 1 skimmer, 2 returns. It was built in the early 60's and is screened in. This setup was installed (thrown together) somewhere around January this year (not by me). I'll be using a suction side cleaner in the skimmer, don't have one yet.
    I have an order in at Amazon for a Pentair 355003S that is a 1hp 2 speed, but I'm not sure it's ever going to ship... So I was just looking at other options. Looks like the Century 3/4hp B2980 would be a good (better?) option, and I'm guessing plenty for this pool? Would I need to change the impeller if I went with the B2980? If so, would I be better off just going with a B2982 1hp and not have to buy an impeller? Should I just stick with the Pentair direct replacement? Any other suggestions instead?
    TIA!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: 2 speed motor replacement, help with parts/decisions
    The 340038 Superflo is an up rated 1 HP so the B2980 is the correct size for the impeller.
    Mark
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's a great deal on the B2980: http://www.lockewell.com/index.php?m...oducts_id=2248
    Make sure you order a new shaft seal. Do not reuse the old one.
    Jun 2014
    FL
    5
    Thanks! I'll go with the B2980 then.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    The B2980 is what I used and I am very happy with it. I took a lot of pics as I took the old one apart which was useful to make sure the new seal went together right.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2014
    FL
    5
    If anyone happens to be looking for a B2980, I ordered one from Zorro http://www.zoro.com/i/G4482624/?category=6494 with 20% off code "VEGGIE" It was under $200. shipped!
