Results 1 to 14 of 14
Thread: InteliChlor IC40 Cell Light Blinking
    Aug 2014
    Phoenix, AZ
    3
    I'm afraid that my 3-year old InteliChlor is dead. The cell light is blinking green and the InteliChlor manual, page 7: “Cell: Shows the status of the IECG. Green (flashing): The IECG needs to be inspected. The blades may have calcium buildup. The IECG is not producing chlorine.”
    I've cleaned the cell thoroughly, there is no calcium on the electrodes. Is it possible that it failed after 3 summers of use?
    Has anyone have similar experienced with InteliChlor?
    Mar 2013
    rancho cucamonga, ca
    10
    Re: InteliChlor IC40 Cell Light Blinking
    I just posted the same question a few days ago but haven't received any responses. My IC40 is 2 years old with 2000 hours of run time.
    18,000 Gallon in ground salt pool and spa, Quartzscape, Pentair Easy Touch, Pentair IntelliClor IC 40,
    Pentair Quad DE Filter, Pentair 400,000 BTU Heater
    1 Pentair IntelliFlo VS pump, The Pool Cleaner Sweep
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I'm in my 5th summer and 3rd cell. Luckily 2 were under warranty. Last winter I started shutting it off (Houston area) and using bleach for Cl.
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    Jun 2014
    860
    Typical cell life is 3 to 5 years depending on use.
    How many hours has it run for? They are designed for 10,000 hours if operation but lifetime can be significantly shorter depending on water chemistry.
    Jun 2014
    860
    Quote Originally Posted by coog61 View Post
    That's a very practical idea. If anyone has a Pentair IntelliChlor, Pentair sells a dummy pipe with the proper fittings on it do you can detach your IC and replace it with a straight tube. Since most SWG won't run in the winter due to the cold water cutoff, it's probably better to switch over to manual chlorination.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I assume the reason for the dummy replacement is to prevent freezing damage etc. (usually not an issue here). Or just use one your "dead" ones.
    Jun 2014
    860
    I meant this -
    http://www.amazon.com/gp/aw/d/B002NJ...pi=SL500_SS115
    It's just a straight pipe meant as a dummy to be placed where you'd normally have the cell. In some areas it's advisable to remove the cell over winter so there's no chance of freezing damage. Here in Southern AZ, the pool water flows all year round so there's little chance of freezing but it does get cold enough that the cell will stop generating. So this pipe would be a way of still running the pool but without a cell.
    Mar 2007
    Murrieta, CA
    215
    I just wonder if there's any harm to just leaving the cell in place, but shutting it off or unplugging it. That is essentially what I have done over the last 7 years. Of course, I'm now on my 3rd cell...
    I'm in So. California, so the freezing risk is negligible..
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Jun 2014
    860
    Quote Originally Posted by peterl1365 View Post
    Seems very reasonable. I left my cell in place and active all last winter. When it got cold here, the cold water cutoff kicked in for several weeks straight so the cell stopped generating chlorine.
    I'm not sure which is better for extended cell life - leaving it in or shelving it.
    We simply don't get cold enough here in Tucson to worry about prolonged freezing damage as our daytime temps are almost always well above freezing. I would be worried if I lived in a different climate where prolonged freezing is an issue and would therefore remove the cell.
    susa's Avatar
    Oct 2010
    Deep South
    578
    1. Ensure your Salt level (take precise measurement, NOT at pool store) is 3500 -- 3700
    2. Calibrate cell using this link
    Jun 2013
    Southeast
    78
    I ran Muriatic acid through the blades, and then I placed it back into the Intellichlor. The blades can accumulate calcium from what I'm told.
    24x32 feet, In-ground, Saltwater, Gunite pool (under construction)
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Just a suggestion for those of you who have been through more than one cell. I replace my good cell with a bad cell during my NON-SWG use during the winter, so even if I'm running the pump, I'm using a dummy SWG that went bad in the past. It's a 5-minute switch. You don't need to buy the dummy piece.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    May 2014
    Bloomington, IL
    11
    I am having the same issue with cell light blinking. I've cleaned mine as well and no changes. Is the consensus that it must be replaced? I can add regular chlorine if I shut it off correct?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I had the same situation and had to replace. Yes, use bleach (chlorine) in the mean time. See Pool Math for volumes.
