Results 1 to 13 of 13
Thread: Help setting up new Stenner pump
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    So I finally got a Stenner pump & tank from US Water Systems
    I got an 85MPHP40 , so it's a single head fixed 26-100psi pump (#7 tube , 1.67gph) & I sprung for the 30gal tank
    First off it fits a little tighter on my equipment pad than I expected ......
    Should I be worried placing it that close to the heater ??
    Liquid chlorine isn't combustible right ?
    The heater is covered in a composite case that doesn't conduct too much heat & the main vent is on the opposite side.
    SO How do I hook this thing up ??? Im sure it's easier than it looks , LoL
    Does it really matter if I put the injector at the top or bottom of the chlorine feeder as long as the valve is opened all the way ??
    I have the popular Woods 50015 digital outdoor timer enroute from Amazon too.
    Thanks for any&all advice !!!
    oh & I guess this will probably make cleaning the filter more work with it installed there ......
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Help setting up new Stenner pump
    Liquid chlorine is mostly water and is not combustible. Only you are going to be able to determine if that area gets hot enough to melt/deform the Stenner tank.
    Yes, you should be able to inject into either port on the tab feeder.
    Support the site
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by tim5055 View Post
    good
    yeah , I guess so
    Great
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Liquid chlorine is non-combustible, but loses strength much faster when exposed to heat.
    Jun 2014
    860
    You need to move the clamp on the filter housing 180deg to the other side or else it's going to be a pain to open and close your filter.
    Otherwise, SWEET SETUP!!!
    PS - you'll be fine with the MasterTemp as long as the exhaust is unobstructed.
    Honestly though, it's kind of dumb that they construct the container our if BLACK plastic ?!?!? Talk about a heat absorber.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by SunnyOptimism View Post
    yeah I thought that too after staring at it a while, going to disassemble & clean filter this week before I fill the tank up
    exhaust is pointed up on opposite side
    I debated on the white vs the gray but the Stenner website claims "UV resistant gray or Translucent white" on the tanks so I ordered gray
    http://www.stenner.com/products/tank-systems
    Quote Originally Posted by Abigail K View Post
    I'll monitor it this winter when I fire up the heater
    May 2014
    Franklin, NC
    9,184
    I think you are going to love the Stenner. Mine has made my life very easy. We travel every two to three weeks and worrying about the pool is no longer part of the equation. With a full tank mine will go about 3 weeks without a refill. I think even with the hi test chlorine you have access to you will not have a problem with % degradation before it gets used in the pool.
    Keep us posted.
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I assume heat is a little lesser of an evil than light is, that's why the tank is black. That said, we have a 300 gallon tank of 9% bleach sitting next to our cooling tower at work in case the chlorine plant goes down, and it is white. Not sure how fast it degrades.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    above pic of exhaust on right side of heater
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Got the timer & all buckets from Amazon with these lids so I can fill up at NAPCO http://www.amazon.com/The-Gamma-Seal.../dp/B0089QJQTS
    Should I put teflon tape on the injector threads that go into the puck chlorinator ?
    Jun 2014
    860
    Nooooooooooooooo....Teflon tape is eeeeeeevil!!
    (I have had many clogs in small tubing caused by errant shards of T-tape)
    Use a liquid Teflon thread sealant (found in same section of hardware store as PVC piping). Works just the same as tape, makes a great seal and is easily removed.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by sunnyoptimism View Post
    nooooooooooooooo....teflon tape is eeeeeeevil!!
    (i have had many clogs in small tubing caused by errant shards of t-tape)
    use a liquid teflon thread sealant (found in same section of hardware store as pvc piping). Works just the same as tape, makes a great seal and is easily removed.
    ok , Thanks !!!
    Jun 2014
    860
    Quote Originally Posted by cnatra View Post
    ok , Thanks !!!
    Like this -
