Thread: Confused by the FC CC test directions for the Taylor 2006
    Aug 2014
    Valparaiso IN
    2
    Hi,
    I'm very new to my pool which came with our new house. We opened the pool in August (I know bad idea) and there was dark green algae so I hit it with unscientific amounts of bleach. I'm muddling around trying to figure out the proper way to do.... everything.
    I've bought the Taylor 2006. I don't understand the note in the chlorine test that says "For one drop = 0.2 ppm use 25mL sample. For one drop = 0.5 ppm use 10mL" How can I figure out what one drop equals???
    My pH is 7.2. Can I do an accurate CYA since I over bleached the pool last week? The pool is mostly cloudy but the shallow side I can see settled dead algae which I vacuum up.
    Thanks
    10,464 gal, IG vinyl with fiberglass steps, Sand filter Pentair Tagelus model TA 60D, pump Pentair Superflo (Idk how to tell it's speeds) pool built June 2012, Taylor K - 2006, a pool heater, Rainbow Lifegard Chlorine Feeder
    38,301
    Re: Confused by the FC CC test directions for the Taylor 2006
    Welcome to TFP!!!
    For the FAS-DPD, use 10ml of water in your vial. Then each drop you count is 0.5ppm. No need for more accuracy than that by using the 25ml of water.
    The CYA test is not affected by the FC level. You should test everything and post up the numbers.
    Take a look at the Extended Test Instructions or the youtube videos at tftestkits.net for help with the testing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    The 10 ml sample is accurate enough.
    Aug 2014
    Valparaiso IN
    2
    So
    FC 3
    CC 0.5
    pH 7.2
    TA 110
    CH 400
    CYA 100
    38,301
    Do the diluted CYA test as described in those extended instructions to find out how high the CYA really is and how much water you need to replace.
    Nov 2013
    Fort Worth, TX
    114
    Your FC is low for CYA of 100. Go to pool school on this site and there is a chart that will show you the FC you néed with your high CYA. To get your CYA down, you will need to drain about half your pool water.
    True....it could be quite a hit higher than 100!
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
