Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Installing an INTELLIFLOW variable speed pump
    I need step by step instructions on installing an INTELLIFLOW variable speed pump and integrating it with my Aqualink RS8 control unit. I am also concerned about the plumbing as there appears to only be one threaded pipe with the remainder having been glued in place. My pool is 35K gallons w Chlorine system. I have a spa, waterfall and heater attached to this in-ground system.
    35,000 gal, Pentair Nautilus FNS 60, waterfall, spa, expensive
    Jul 2012
    Dallas
    43
    Re: Installing an INTELLIFLOW variable speed pump
    Can't help with the Aqualink integration but the easiest way I found was to remove the motor from the weir on the existing pump and then cut the upper pipe and then turning the weir to remove the intake after unscrewing the output. Looks from your pics like they added some silicone to the intake but it should still be threaded. I didn't use couplers for the output but in hind sight would use them if I have to do it again. 2" PVC isn't very giving in short runs.
    26k gal, IG, Pebble Tec, DE filter/48sq'/144 GPM, 3hp Intelliflo running @ <1400 rpm 24/7
    bulldogz400's Avatar
    Jun 2014
    Las Vegas
    128
    If you're doing the install you may as well incorporate the unions for easy removal at any time. Nt sure if you have these already -
    http://www.backyardpoolsuperstore.co...NslRoC3wfw_wcB
    IG gunite 32 x 18 on a bachelor budget! Click Here To See
    Where's the weir?
    Quote Originally Posted by bulldogz400 View Post
    Thank so much. I agree with you on this. The pump I'm considering purchasing is the Pentair 011018 and it has the couplings with it.
    Jun 2014
    Las Vegas
    128
    Interesting! That is the exact pump I have and it did not come with the unions. Good luck with the install!
    Oct 2013
    Chapin, SC
    1,141
    Yup, mine was installed yesterday. No couplings in my box either.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Ebay seller has a package deal for $899.
    http://www.ebay.com/itm/390872629580...%3AMEBIDX%3AIT
    So my pool guy came by today (I've kind of failed at keeping algae down during the summer) and I mentioned this pump and he was totally against it. He claimed to see a lot of failures out in the field. Can anyone speak to this. Even if a component failed after a year, the cost savings in electricity seems likely to surpass the costs.
    Oct 2013
    Chapin, SC
    1,141
    If you have a certified pool tech install it, it has a three year warranty instead of a 1year for a DYI installation.
    That's good to know. Thank you.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I bought the same 011018 pump for $835 w/ free shipping, no tax. Another $25 for the couplings which are very nice, they have O-rings that seal against the pump, makes the install easier. You can also get a $100 pre paid Visa card as a rebate from Pentair and an extended 3 yr warranty if you have the pump professionally installed.
    Bought pump here
    Rebate form here
    chiefwej
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If the consumer purchased new pool electronics, it will only have a 1 year warranty if you install it, even though you paid full retail for it...I hope that never catches on in other things like we purchase...like voiding your pool warranty because you didn't have a pool service company taking care of it..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    patrick3229's Avatar
    Feb 2012
    258
    Here are the step by step instructions you asked for on Installing a Pentair Intelliflo Variable speed pump http://www.inyopools.com/HowToPage/h...o-vs-pump.aspx I hope this helps.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I was planning on installing the pump myself, but getting the extra $100 rebate and an extended 3yr warranty changed my mind.
    chiefwej
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by chiefwej View Post
    I wonder how much it would cost to install a replacement pump?
    Autopilot SWG
    Oct 2013
    Chapin, SC
    1,141
    My cost was $175. Included initial service call to diagnose the old pump and 1 hr labor and materials. I got mine the same place as chief.
    Thanks Patrick. It's definitely great to have those step by step instructions. What's really got me stumped is interfacing it with my RS8.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    $175 is pretty cheap...
    Autopilot SWG
    Oct 2013
    Chapin, SC
    1,141
    And there's a $100 rebate for professional installation! And a 3 year warranty instead of 1 for a diy!
    Aug 2014
    Redding CA
    7
    The Pentair rebate form says "pump must be purchased and installed by a pool professional". The online prices may be much lower than available through a pool professional - does anyone have experience with this?
    My local utility has a $400 rebate for installing one of these pumps. Playing my cards right this could be a inexpensive upgrade. http://www2.reupower.com/pdf/rebates...mp-2014-07.pdf
    2005 - 38,000 gal Seafoam Green Pebble Sheen with waterfalls, WhisperFlow Pumps, 540 sq ft cartridge filter, 2011 - Kreepy Krauly Legend cleaner, 2013 - Intelliflo filter pump Jandy iAqualink RS4, Taylor K2006, 2014 - Changed lights to Jandy LED Watercolors which failed 20 months later after little use, 2016 - Added Pentair Intellichlor IC60 - Running 40-60% 8 hours during season
  20. Back To Top    #20
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I bought my pump online at the site I posted above and had it installed by a local pool service. Per Pentair my Rebate has already been approved. According to Pentair, to qualify for this rebate the pump must be bought retail (online retailers are OK) and it must be professionally installed. Professional installation can include a licensed electrician, pool service, plumber, etc.
    chiefwej
