Results 1 to 9 of 9
Thread: Where do you buy your cya?
    Aug 2014
    East Northport, NY
    155
    Interested to learn if there is a preferred brand or web address to purchase.
    Thanks!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Re: Where do you buy your cya?
    Home depot.
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Walmart is the cheapest. HTH brand, dissolves quickly. In a pinch I've purchased a big ol' bucket online and some at Menards or Fleet Farm but those tend to dissolve much more slowly.
    Isolated Spa - 345 Gallons
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    As long as it is 99% or greater CYA it's fine. If you don't need it immediately you can get good deals on eBay, but of course shipping will take some time. Other than that Walmart or Home Depot.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Walmart
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2014
    Dallas, TX
    20
    Quote Originally Posted by svenpup View Post
    My home depot only carries the HTH brand, which is 96%. I guess it depends on location, since their website shows another brand, "Pool Time" with 100%.
    I get mine online once or so a year, a 25 lb bucket ay Inyo pool, when they have a deal. This year it was a fairly fine powder, which surprised me. Seemed to work as expected with raising CYA, and dissolved fast, but doubt a few % difference in purity would be noticeable in any test!
    25000 Gallon gunite and plaster, 100 perimeter feet. Pool built 1996, original owner.
    Uniclor 2400 external brine membrane chlorine generator.
    Kreepy Krauly inground cleaner, suction side.
    Sta-Rite System 3 filter, 300 sq foot cartridge with 1.5 lb cellulose filter aid used.
    Sta-Rite Max-E glass 2 HP pump, Solar Cover for heat retention and evaporation control.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    96% is fine...I guess I should have said "mostly CYA" or "CYA as the only ingredient"
    FlyAU98's Avatar
    Jul 2014
    Ft. Lauderdale, Florida
    59
    My pool guy delivered it via pucks he hid on the ledge inside my skimmer! Maybe I can send you my water!
    15.5K gal, concrete, 1HP AO Smith pump, Hayward C1200 cartridge filter, Zodiac T5 Duo auto cleaner, 8 panel solar heater controlled by Hayward Aqua Solar GL-235
    Quote Originally Posted by FlyAU98 View Post
    That sounds familiar, but mine put them in the skimmer and the puck feeder tube.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
