Thread: Adding Z-Wave device to Intermatic controller
    Apr 2013
    Delaware Beaches
    59
    I've got an Intermatic PE15300 Panel with PE1353ME Timer & PE4243ME Switch controller set up to control my filter pump and booster pump. I also incorporated the PE650/PE950 Remote and Transceiver whcih gives me remote control on the Heater and Light in the pool.
    I am now trying to add a GE 45609 Z-Wave On/Off Switch to the Remote/Transceiver. I followed the instructions to include the device in the network and it isn't responding. Any ideas?
    (Steps are to Reset the device, Include it in the network, Add it to the scene, done.)
    Built March 2006 - 26k gallon, Pacific Pools 18'x36' Roman end vinyl liner, 8' Roman steps one end, Sand Dollar SD80 filter, Pentair Pinnacle 1HP pump, Pentair Letro 3/4HP pressure side booster, Pentair Letro Legend Platinum cleaner, Sta-Rite Max-E-Therm SR400LP, Hayward CL200 chlorinator
    Added April 2013 - Intermatic PE15300 (1353ME timer & 4243ME switch, PE650 transceiver, PE953 remote, PA122 temp sensor)
    TF-100 XL w/ SpeedStir
    Nov 2013
    Fort Worth, TX
    114
    Re: Adding Z-Wave device to Intermatic controller
    I'm sorry I can't answer your question, but I would like to know how you like the Intermatic setup? I'm thinking of using the same equipment to control my pump, booster pump, Stenner pump, heater and two valves. Was it easy to install? Can you do everything you want from the remote?
    Good luck with your Z-Wave.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Sometimes you need to remove the device before adding it - as if that makes any sense.
    Steve ~16K IG Vinyl Pool, Hayward TriStar 1.5 hp, Hayward S244TE filter, Polaris 280 w/booster pump, Prologic PL-P-4, Hayward AquaConnect, 3 PAL LED lights, 3 Deck Jets, AquaComfort ACT 1100 heater and TF-100 Test Kit with SpeedStir.
    Apr 2013
    Delaware Beaches
    59
    Sorry for the delay in responding... Long few days at work...
    @Billrector, I really like the setup very much. I currently use it to control the main pump, booster, pool light, and heater. All four are controlled by the remote, or at the panel. I have two lines coming to the panel - 220v for pumps, 110v for light & GFCI. Be sure to read, re-read, and re-re-read the PDFs for all the equipment. I found it helpful to make up a wiring diagram before I got started. I also installed a GFCI in the panel for powering the blower for winterizing, and a dimmer to set the pool light level. It just took a lot of planning on my part to get it all to work right. I have the 1353 set for Mode 5 for control. Also, I set up the clock to use the 110v line for power since I cut the 220v breaker to pumps after winterizing. When the clock loses power, the time is reset but it keeps the timer events up to like a week. It also has delays built in that need to be enabled for the booster pump and heater to ensure good water flow. The heater also has a time delay off, so if you turn off the system with the heater on, it will turn off the heater and run the pump for another 5-10 minutes to do cooldown. It just uses the fireman switch for on/off and monitors the temp via the PA122 sensor - the heater panel is bypassed. Please feel free to post/PM if you have questions, but it may take a day or two for replies depending on work. Also ,be advised that Intermatic doesn't really seem to respond to the "Contact Us" form for tech support.... I'm still waiting on answers from last year that I already answered myself.
    @IpaFan, Yup, makes perfect sense. I run Z-Wave in the house too. Removing didn't help.
