Thread: Low suction when vacuming
    Apr 2012
    South Dakota
    87
    Within the last month the suction when vacuuming has dropped significantly. I always prime the hose before I start vacuuming but there are a few spots that hover toward the surface. Could that point to a air leak in the hose? I assume the hose should submerged since it is full of water and air in the line would make a few spots float?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    Apr 2012
    South Dakota
    87
    Re: Low suction when vacuming
    Still have this issue even after trying a different hose. Can't figure it out.
    Without the hose connected I can close the main valve so the skimmer is pulling everything in and there are no bubbles. When I put the hose on the water level in the basket drops and the pump is really working. I can pull the hose and engage the main to get water in and everything is fine.
    Vinyl liner
    Taylor K-2006
