Thread: Any thoughts on fighting algae growth on Kool-Dek Surface
    I have had a constant battle with algae growth on my pool deck surface (Kool-Dek) since pool was installed about 2.5 yrs ago. I was if anyone had any input on how to fight the battle? I have one area where the deck has a low spot and it puddles which obviously does not help, but there is also other areas of the deck with problems that have a proper slope still grows algae quickly. (pool deck is shaded alot of the day and that is root cause I am sure) I am tired of bleaching/pressure washing every 2-3 months. I know they make sealers but not sure if they would help and I fear they might yellowing/peeling etc. , not sure about durability of the sealed surface. Anyone have any advice?
    Jul 2008
    144
    Re: Any thoughts on fighting algae growth on Kool-Dek Surface
    A good paint or sealer will work. Be sure to get something that is made for pool decks. Be sure to get something that wont be slippery. You can fill in the low spot with some kool deck patch before painting.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Check out the link below. I also have Kool Deck and thinking about using it on my deck. A may pick up a repair kit also.
    http://www.kooldeck.com/products/kpad.html
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
