Thread: green powdery dust
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    green powdery dust
    I am getting a buildup of green buildup on the walls of my pool. When you brush it down it just looks like a green dust cloud. The pool is crystal clear and everything checks out good except the cyanuric acid which is around 150. My local pool company suggests it might be pollen and I used and followed their reccomendations without any luck. Any suggestions? Pool is around 13-15 thousand gallon, using a DE filter system. I run it for about 6 hrs a day. While doing the reccomended treatment I ran it for a period of 24+ hrs.
    Thanks in advance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: green powdery dust
    Welcome to TFP!
    More than likely it is algae. Your high CYA renders your chlorine nearly ineffective at the levels that pool stores and most of the pool industry recommend. Even at 100ppm CYA, you want to keep your chlorine at 12ppm.
    The CYA test is not accurate at levels above 100ppm, so your real level could be much higher.
    Aug 2014
    44
    So what do I need to do? Drain the pool down some and refill?
    Jul 2013
    Gilbert, Az
    116
    Well to start how are you testing? you should look into the test kits that are recommended here. You will have to drain to get your CYA down use pool math to tell you how much you need to drain if the CYA test is accurate
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Jun 2014
    860
    green powdery dust
    Quote Originally Posted by bponb View Post
    For starters, you need to stop listening to pool stores and "experts". They will only lead you astray.
    Second, you need to read all the links in Pool School to learn about how to take care of your pool yourself. Basic Do It Yourself pool maintenance is really easy and will save you lots of money in the long run.
    Third, you need to test your own water. You need to use either a Taylor K2006 or TFP TF-100 test kit. You can't use test strips or pool stores for water analysis. You have to do it yourself, it's the only way to get accurate results.
    Finally, you need to post a full set of test results and let the experts here help you. The TFPC Method is super easy to do once you get the hang of it and this forum has thousands of users online at any given time if the day ready and willing to give you lots of good advice.
