Thread: Pool liner replacement question
    May 2009
    Hampton, GA
    15
    My liner is leaking rapidly. I have decided to replace the liner but want to wait until beginning of next season. Does anyone know if leaving old liner in with little or no water until next spring will effect the pool sides or damage them? Or do I need to replace liner now?
    kbpool
    AG,vinyl
    13500
    cartridge filter
    Waterways, 1.5 HP pump 2 speed
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Pool liner replacement question
    It is a bad idea to leave the pool empty or really low over the winter. You run the risk of the sides caving in. My sister lost her pool this way a few years ago.
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Why don't you patch what you have and replace in the spring?
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    May 2009
    Hampton, GA
    15
    I have tried patching and still leaking. I will try again and refill to skimmer to keep walls from caving. Thanks
    kbpool
    AG,vinyl
    13500
    cartridge filter
