Results 1 to 13 of 13
Thread: Leak at pump junction
    Jul 2014
    Chapel Hill, NC
    40
    Found a small leak at the junction of of the 1.5" PVC where it exits my pump. It appears to be a threaded connection. Is it possible to simply unscrew the connection and either replace or add teflon tape and retighten? Or, should I plan to cut the PVC, remove the threaded connection, replace it and join it with a coupling or union? Haven't tried to unscrew it yet as I didn't want to damage it. Thanks for your advice!
    30,000 gal IG pool, vinyl liner, Hayward Superpump 1 HP, Hayward S244S sand filter, Zodiac LM2-24 SWG, Polaris 280 TankTrax cleaner, TF-100 and Taylor K-1776 test kits
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Leak at pump junction
    I'd recommend pipe dope over tape. Make sure you get the kind that is intended for plastic pipe.
    Whether you can unscrew depends on how the rest of your plumbing is done. It may just need tightening, but be careful. The pump can get cracked if you go overboard.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    It depends on the fitting. Some are pipe threads and some are O ringed. My pump leaks at the same spot. If pipe thread then pipe compound or teflon tape will work. I'd still put in a union for ease of replacement or repair. I was in a hurry so I cut the pipe, wrapped it with teflon and then used a rubber butt fitting with clamps to reconnect the sawed in half pipe.
    Have since taken it back apart and added a union.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2014
    Chapel Hill, NC
    40
    Thanks for the help. I'll get out there this weekend and work on it.
    Jul 2014
    Chapel Hill, NC
    40
    The guy at Lowe's recommended that I use the red Oatley's multipurpose cement to join the adapter and coupling and Rectorseal #5 as pipe dope on the threads going into the pump. I'm using 1.5" PVC schedule 40 pipe and coupling. Do these products sound reasonable or would you recommend something different?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Those recommendations are fine. If you don't have a pipe sealant yet the better choice would be Megaloc. http://www.homedepot.com/p/Hercules-...8062/100153125
    Jul 2014
    Chapel Hill, NC
    40
    Thanks kiss4afrog.
    SW Indiana
    9,199
    Make sure your pump has a 1.5" port before you take things apart. Many pumps have 2" threaded inlets and outlets and you need a 2"male thread X 1.5" female slip coupler, which is not commonly found in hardware stores.
    Jul 2014
    Chapel Hill, NC
    40
    Ok, thanks JohnT. Where do you buy a 2-1.5" coupler? Online? I also noticed that the owner's manual for the pump contains a warning not to use plumber pipe dope as it can cause cracking of plastic components. The manual recommends teflon tape. Is this a common warning that can be ignored or something specific to my model and I should use teflon tape? It's a Hayward superpump, 1 hp, model SP2607X10. Thanks!
    May 2013
    Fort Lauderdale, FL
    423
    I get my PVC fittings from these guys. Fast shipping and HUGE selection. I buy a few extra of everything because they're so cheap and keep them for spares if you have to replace any equipment down the line.
    https://www.plumbingsupply.com/pvc.html
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    SW Indiana
    9,199
    Quote Originally Posted by adrob2 View Post
    I think you have 1.5" fittings so you should be covered at local stores.
    If the manual says tape, that's what I'd stick with I think. You can crack the housing, so don't tighten it more than you need to. Always makes me nervous installing threaded PVC fittings because I'm afraid it will leak or break.
    Jul 2014
    Chapel Hill, NC
    40
    Thanks for the help JohnT. I'll be careful and try not to think that "tighter must be better"! I'm pretty sure that the adapter is just 1.5" but my local Lowe's has the 1.5 to 2" adapter if I'm wrong.
    Jul 2014
    Chapel Hill, NC
    40
    I got it fixed yesterday. Ended up putting in a union and using teflon with some silicon grease (got a little sloppy with the primer though). Thanks for all of your help and input!
