Thread: Borate test strips
    May 2014
    Dfw
    29
    Borate test strips
    I've got just under 25 lbs of boric acid in the pool right now and I started with zero. This is what the strip is saying. I do the math and the calculator says 25lbs should put me in the 40 ppm range. I'm shooting for 50 but these strips are making me nuts.
    14k gallon, vinyl in ground, 1 hp pentaire pump, pentaire sand filter, taylor k2006 kit,hayward shark vac cleaner, pool blaster cg vacuum
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: Borate test strips
    I say that looks like its between 30 and 50... so just call it a day...
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
