Thread: Help with ground prep
    May 2014
    Wisconsin
    3
    We are getting ready to install a 27 foot aqua leader pool. We had someone come out to dig the hole. We have mostly sand and rock here. W have spent a few days trying to pick out the rock and for some reason a pretty good amount of glass of of this hole. We are kind of at a loss because we feel like no matter how long we are out there we are never going to get it all and the amount of glass out there scares. I was reading somewhere about putting crushed limestone down and compacting it for a solid pool base. I'm wondering if maybe this is the way too go to make sure the glass doesn't come through the liner or if there is a better way or maybe we just picked a really bad spot in the yard to put a pool. Thanks in advance.
    38,275
    Re: Help with ground prep
    Welcome to TFP!!!
    I think putting down a clean compacted base might be a very good idea in this case. Sorry this is not starting off well for you.
    May 2014
    Wisconsin
    3
    Rocks and glass in new build
    Merged by moderator. Please do not post the same questions multiple times and keep all related discussion together. Thanks, jblizzle
    We dug out for our 27 foot aqua leader pool and have been picking the rocks and other things out of the site. We have pretty much nothing but sand and rock for soil in the site along with a pretty good amount of glass that I'm not sure where it came from. I'm wondering if the site needs to be 100% clear of rock because I think we may be digging to China before that would happen. I'm also concerned about the glass. Is the few inches of masonry sand that you put down under the liner actually going to protect the liner from this stuff? I read somewhere about putting compacted crushed limestone for a base. Would this help to seal out all the glass and rock that appears to be in our site or would that be a bad idea. Not really sure what to do here. Thanks in advance
    May 2014
    Wisconsin
    3
    Didn't mean to post it twice
    Jul 2014
    Bastrop, Louisiana
    199
    One method would be to put down a few inches of pea gravel followed by a few inches of clean sand. You could then top that off with optional styrofoam sheets taped together if you didnt feel the gravel and sand would offer enough protection..
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by Ashlee2004 View Post
    I'm guessing you thought your original post got lost as it was waiting for moderator approval. After a few posts your wait will be gone.
    AS for your glass problems, I would be tempted to put some sort of barrier down before the crusher stuff and then a gorilla pad or something similar between the crusher and the pool. It wouldn't be fun for a foot or the pool liner if a piece of glass were to work it's way up.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
