Thread: Solar cover straps
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Solar cover straps
    Hi all who use solar cover reels,
    What are you using to attach the cover to the reel? the straps that came with it disintegrated after <1 season. I bought some rope thinking that it would be better, well, whatever kind I bought also disintegrates in chlorine/sun. Have you found anything that lasts?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Solar cover straps
    I used these: http://www.ebay.com/itm/Replacement-.../400506737374?
    They seem to be holding up ok other that the fact that the adhesive velcro they come with was junk and fell off almost immediately. I stuck them back on with Elmer's Advanced ProBond and it's been 1.5 seasons and going.
    ...........[Edit]............
    On closer look those are just the fastener plates I ordered when I got a new cover. In that case I think the straps are still the original ones that came with the reel. I think it was this one and I think these are the straps that came with it. Since I now believe that these are the original ones that came with the reel it must be 3 seasons by now.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
