Thread: Aqualogic P4 system - intermittent Chlorinator Off - No Flow error, help please
    Automation System: Aqualogic P4
    The Chlorinator model is AQL-TCELL-15
    The SWG is on its 5th season (my season is 4-5 months), last year I had mistakenly left the SWG on while dumping in salt for my opening and I blew out the circuit on this board that everyone blows out on the Aqualogic, I had someone out that cleaned the board and re-soldered the point and I was good up until now, but this is a totally different error.
    Intermittently I will see the error Chlorinator off - No Flow. I know it's not my pump because my Heat Pump is able to run and my PSI looks the same.
    At times the message disappears, but I notice it lasting longer and longer.
    Can someone please walk me through the process of troubleshooting.
    Thank you.
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Re: Aqualogic P4 system - intermittent Chlorinator Off - No Flow error, help please
    It's worth mentioning that I just did a quick chlorine test and there is plenty of chlorine being generated.
    today it's been working without any issue at all, very confused...
