Thread: FAS-DPD I forget.....
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    What is the best way to test at very high chlorine levels? In order to reduce reagents used? I forget. I don't see it in the extended test kit instructions.
    I didn't think it included any dilution.....a search brought me to that. I need to order reagents but also need to slam.
    Isn't there a way to test (less accurate) CL levels in the higher double digits with less reagents?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: FAS-DPD I forget.....
    Are you thinking of 10 ml instead of 25 ml and each drop being .5 instead of .2 FC?
    Some people have tried 5 ml with each drop being 1 FC, but I think I read that accuracy really suffers when it's that concentrated. I've never tried it.
