Results 1 to 9 of 9
Thread: Ladies stockings to add CYA to skimmer?
    May 2014
    Pflugerville, TX
    148
    As a way to 'sock' my CYA, can I use ladies stockings? I use them to keep humidity beads in my humidor and I have some spares that could be used to 'sock' my CYA granules.
    Does anyone see any reason against this?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Oct 2013
    Chapin, SC
    1,141
    Re: Ladies stockings to add CYA to skimmer?
    I've seen where some folks have torn a hole in them dumping all the Granules to the bottom. I'd use old hole-less athletic socks if I were you.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by timerguy View Post
    I don't know that I have any I'm willing to sacrifice right now.
    Oct 2013
    Chapin, SC
    1,141
    No need to sacrifice, I've used the pair i'm using 3 times already, they look like new. No stress, no mess emphasis on the mess part.
    https://www.dropbox.com/s/c7pfqu2oub...2011.52.43.jpg
    https://www.dropbox.com/s/vm58hct7id...13.32.41-2.jpg
    May 2014
    Pflugerville, TX
    148
    Meh. I just went for loose cya in my skimmer baskets. Ran about a pound per basket through until it cleared out of them and the pump basket and then repeated the process again. Gonna see where 4 lbs lands me (poolmath wanted 6.5)
    Noticed no changes in the pump pitch or flow. Was careful of that.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Home Depot has 1 gal paint strainers, work great. Cheap
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    wjr75's Avatar
    Jun 2013
    IL
    836
    I use my wife's old panty hose. make sure to use the brown ones. I used black ones once and they started to leach the color.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by wjr75 View Post
    I was going to use white.
    May 2014
    Pflugerville, TX
    148
    Well looks like my CYA is up to 60 from 30. I'm still going to wait until a week to get a 'final' number before adding more to get up to 70.
