Thread: Multi-port Valve Question - Losing Water
    Jul 2012
    Houston, Texas
    9
    Should there be sitting water in the crevice on top near the handle? We recently had a pool company come out and replace the multi-port valve and booster pump and have since been losing water. I can only imagine the valve top isn't seated correctly onto the gasket or there is a defect in its construction. We are sitting some sitting water on top though and wondered if that was normal.
    Beyond that, I can only assume there might be leaks in the return lines since we hadn't ran a booster pump in some time. The water loss seems to only really occur with the pump on, so I imagine one of these two is the culprit.
    Appreciate it.
    17,000 Gallon In Ground Plaster -- Installed around 2001
    DE Filter - 1.5 HP Challenger Pump - Polaris 380
    30,432
    Re: Multi-port Valve Question - Losing Water
    Can you see it leaking?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Is the water just sitting on top of the valve or dripping down the sides as well. I wouldn't imagine just a small amount of sitting water (very small leak) on the valve would cause a noticeable water loss. It's more likely related to the booster pump or the lines associated with it. Please be more specific and investigate some more.
    Isolated Spa - 345 Gallons
    Jul 2012
    Houston, Texas
    9
    No, I don't see it leaking anymore than just the water sitting on the top of the valve. I guess I could clear it up with a towel and run the pump to see if it refills. I just didn't know if it was normal to have water sitting in the grooves if the valve was functioning properly.
    I don't believe this is where the water loss is coming from, I'm just wondering if it is a symptom that the valve itself is leaking more inside the chambers.
