Results 1 to 9 of 9
Thread: PoolMath vs Chlorine/CYA Chart
    Fort Worth, TX
    83
    I'm a little confused about the proper FC / CYA levels.
    I have a CYA of 30.
    PoolMath gives the proper FC range of 2-6 ppm FC
    The Chlorine/CYA chart gives Min 2 / Target 4 ppm
    I bring my FC to the "proper" level every evening.
    Should I top it off at 6 ppm or 4 ppm?
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: PoolMath vs Chlorine/CYA Chart
    Whatever level you need to ensure it never drops below 2ppm. Depends on your daily chlorine loss.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    If you are losing more than 3 or so FC ppm daily, consider increasing your cya level. I'm at 60 CYA 3 hours East of you and still do as an example.
    Fort Worth, TX
    83
    Quote Originally Posted by woodyp View Post
    I think I'm okay in that regard.
    I've been topping out at 6 ppm every evening. I lose 2.5 ppm a day, max.
    I started about a week ago topping it at 5. Since then 1.5 - 2 is the most loss I've seen.
    May 2014
    584
    In that case aim for 5 so that you have a little bit of wiggle room with your FC.
    Fort Worth, TX
    83
    Quote Originally Posted by Abigail K View Post
    How do I aim for 5?
    Does that mean make 5 my minimum?
    Bring it up to 5 every evening?
    38,239
    That means target 5 so it does not drop below the minimum by the next day.
    Fort Worth, TX
    83
    Let me try to nail this down.
    "Target" 5?
    Lets say that late this evening I test FC and it reads 3.5
    Should I add enough bleach to bring that reading up to 5?
    My minimum is 2 ppm. CYA is 30.
    38,239
    Yes.
