Thread: Help with filter size.......
    Aug 2008
    Eastern Washington State
    11
    G'Day All,
    I need help with sizing a sand filter. Money is an issue, so I would like to get the smallest filter (price) and yet provide adequate filtering for the pool. I have a good pump, but don't know the flow. The pool store says they need to know the flow before they can recommend a filter. It is a 1HP pump made by Hercules, w/ 1.5" in/out. It has no flow markings at all. I don't want to undersize the filter flow and burn out the pump. The only info on the pump is the motor info itself, which is a Century motor. Your assistance is appreciated.
    TJ.
    21' AG, 10,000 gal, 22" Sand Filter, 1 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help with filter size.......
    The difference between an 18" and 24" sand filter is only about $50. I'd go with the 24" in a heartbeat.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    FWIW, my 1 HP pump delivers about 30 GPM, but that's with the sand filter(100#) and solar on, so it was lifting the water 12 feet up.
    I think any filter with a max. flow rate of 50 GPM or more will work. Generally, you can't have too big a filter. I would shoot for something in the 100 - 300 lb. range. Then again it seems that a lot of sand filters are now rated in Inches(which I have no clue about).
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Aug 2008
    11
    Thanks, Adam & John.
    I see what you mean about the price, although many of the places I've found show much more than $50 between them --- some as much as $150. That is why I was concerned.
    It is confusing to me, though, how they (Hayward) can put a 1.5 hp motor on an 18" filter. Seems the flow would be restricted????
    Oh, Well.
    Thanks for the input. The PS, I think, just wanted to sell me a whole setup, not just the filter. Go figure!!
    TJ.
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    The 1.5 hp would be too much pump for the sand filter size you are looking at purchasing. Not to mention the fact your electricity usage would increase with no real benefit in filtration. I used to have a 16" Hayward sand filter with a 1hp pump on a 18' ag and it was more than adequate. I've recently switched to a Hayward cartidge filter. I would go with the larger filter as well.
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
    Guest
    Please check your private messages (link on upper left corner of page)
