Thread: Waterlink Spin Lab & Taylor K2005 results are giving different hardness measureme
    Aug 2014
    San Antonio, TX
    6
    I've got a Taylor K2005 DPD test kit that I'm using to test my water.
    Recently a new store opened up in town, that's using the Waterlink Spin Labs, so I gave them a try. Their Waterlink Spin Lab hardness is consistently 70-100 ppm higher than what both I and Leslies get with the Taylor kits/regents.
    Today I ran a "controlled" test. I took 4 samples at the same time from the same place in my pool, in 4 samples bottles. I took one to Leslies, took 2 to two different stores using the Waterlink Spin Lab, and measured the 4th myself -- all tested within a hour of taking the 4 samples.
    The 1st Waterlink Spin Lab measured 193 ppm.
    The 2nd Waterlink Spin Lab measured 205 ppm -- within the tolerance of the measurment.
    Leslies measured 110 ppm.
    I meausred 105 ppm.
    So whose is right -- me & Leslies? Or Waterlink Spin Lab?
    Thank you
    38,248
    Re: Waterlink Spin Lab & Taylor K2005 results are giving different hardness measureme
    Welcome to TFP!
    We don't trust pool store testing, so I suggest you stop wasting your fuel and time and just trust your own testing.
    Btw, you need to add the FAS-DPD chlorine test to have the equivalent of the kits we recommend.
    Aug 2014
    San Antonio, TX
    6
    Thank you for welcoming me on board
    On the plus side, the Leslie's store I used to be another local store that was acquired by Leslies. Some of the guys there are still really good and have given me consistent test results over the years.
    Since my last post, I have another data point. I had a pool service guy out to check something else, and he also got a Calcium Hardness in the lower hundreds. On the other hand, a second round of test on the Waterlink Spins are still reading high hundreds/lower two hundreds. That's a rather large gap.
    I really like the idea behind the Waterlink Spin but there's not a lot of stuff out there about how accurate it really is. There is that one video talking about all the things that can be done wrong, but there doesn't seem to be much about its accuracy when used right.
    So for now, I'm going to trust what I guess now the ole fashion way and figure my Calcium is too low. It's a relatively new replaster that I don't want to mess up. Time to add some CaCl.
    19K IG PebbleSheen, Hayward 1.0HP TriStar, Hayward 7220 DE Pro-Grid, AquaLink RS4, 2x Jandy 2444 JVAs, 5X Jandy 15W Nicheless LEDs, Polaris 3900, Hayward H250FDP Heater
    wjr75's Avatar
    Jun 2013
    IL
    836
    I had my pool re-plastered with pebble sheen in the spring. I initially had a CH of 130 and now three months latter I'm at 300ppm. The new plaster will increase by its self as it cures. Our PB told us not to add any CH increaser due to that fact and he was right.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2014
    San Antonio, TX
    6
    They're telling me it will rise as well. Yet the Pebble Tec startup instructions say I should have it at 150ppm now & raise it to 200ppm by 28 days. That's why I'm kind of hung up on the correctness of these test results because one set is below that 150ppm target and the other set is at/above the 200ppm target.
