Thread: Error codes 180 and 172
    Aug 2014
    NJ
    4
    First new to this web site and posting.
    Pool 16 x 32, not sure of gals 4ft to 9ft depths ( 32,000 gals )?
    AquaPure 1400 ( 4-5 yrs old )
    Notice these error codes today, says to call dealer, I'm good mechanically
    Need help to understand what I should do to correct problems
    Re: Error codes 180 and 172
    You might need the tri-sensor adapter. If you have one already installed, it might not have been installed correctly. Google for the installation instructions.
    If the adapter is installed correctly, then you might need a new tri-sensor.
    Support the site
    Aug 2014
    NJ
    4
    I opened the sensor, cleaned and replaced, worked not for long and revered back to same codes.
    Still get good salt readings, 2.6.
    My thought is just to replace cell and sensor.
    One question though, on new sensor I noticed a small circuit board connected on the cable, this is for??
    That's the tri-sensor adapter. That's probably all you need. It's sold separately.
    Follow the instructions to make sure that it is installed correctly.
    Support the site
