Results 1 to 7 of 7
Thread: Effects of adding fill water calculator
    Jun 2013
    East TN
    309
    I was thinking the other day how a calculator like that would help me figure out where my TA was going to go after adding a few inches of fill water. For informational purposes I would have used it since I knew my TA was going to go up. Input your current test results, fill water test results and gallons of fill. How does that sound for a suggestion?
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Jun 2013
    East TN
    309
    Re: Effects of adding fill water calculator
    Does anyone know the math formula for calculating such a task? Ive tried to work it out on paper but nothing seems to make sense.
    38,271
    For most chemicals it is just a ratio. If you replace 25% of the water:
    New level = 0.75*pool level + 0.25*fill level
    Jun 2013
    East TN
    309
    Thanks for the reply. I came up with a formula before you replied that looks the same as what you replied with. I made a javascript calculator with this formula:
    Total Gallons = Pool Gallons + Fill Gallons
    Pool Gallons / Total Gallons = A
    A x pool TA ppm = B
    Fill Gallons / Total Gallons = C
    C x fill TA ppm = D
    B + D = Final TA ppm when mixed
    Does that look right to you? I am willing to share the calculator with the community here so people will have an idea of what happens when fill water is added to their pool.
    38,271
    Looks right to me.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    To circle back on what jblizzle said in post 3, if you are replacing water, The "Pool Gallons" in you equation is after draining.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2013
    East TN
    309
    I have the calculator made. Had to redo the equations since they got deleted somehow. Anyone interested in checking it out for flaws or suggestions?
    I need some people to check it out. Im sure I will tinker with it some more. Where would I need to put it?
