Thread: Saturday morning relaxing......
    Jul 2014
    Peoria, IL
    389
    Some complain that pools are too much work and the maintenance is too high.
    I just call it Saturday morning. I get up early, grab my coffee, turn the radio on and count drops. Kind of therapeutic.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Saturday morning relaxing......
    Sounds like a pretty good Plan to me!
    No reason to change it.
    I was up an on the patio with coffee, when the sun came up this morning. It's a pretty good way to start a Saturday, or any day for that matter!
    Divin Dave,
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    A pipe is the only thing missing from that table. That would make it truly therapeutic.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2014
    Worcester, MA
    29
    No need for anything else with that coffee cup!
    John
    IG 33K Gallons 20'X40', Hayward Pro Series Sand Filter S310T2 (zeolite), Pentair Intelliflo 3HP SVRS Pump
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by kerryman71 View Post
    John
    Amen!! Hope this year is better on the football field. The star at has been a bit disappointing.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Oct 2013
    Chapin, SC
    1,141
    Is that a phosphate test kit? Certainly you're not using that are you?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
