Results 1 to 8 of 8
Thread: TF-100 test kit
    Aug 2010
    Pekin, Illinois
    8
    TF-100 test kit
    I have been using the TFP methods in caring for my pool for 4 years now and have truly had a TFP. I have been guessing at my pool chemistry except for the daily Chlorine and pH test with the inexpensive test kit. This year we have had a lot of rain and cool weather. I had started to see some green dust around the edge on the bottom of the pool. I started keeping the Cl2 level a little higher (3 to 4ppm instead of 2 to 3ppm). It was not getting worse, but it was not getting better. I decided to get the TF-100 kit and quit guessing at the levels. This is what I got this A.M.
    pH-- 7.2-7.3
    FC--7.5
    C.C--0.5
    CH--275
    Alkalinity--50
    CYA--45
    Borate-- 30-35
    I use liquid bleach/Cl2 @10% that I get from either Menards or Big R's when on sale in the spring for an average of $2 a gallon. I use Muriatic acid. I keep 1, 3" tab in a floater to help maintain the CYA level. Now with these test results, I am going to add some borax and keep the Cl2 higher and allow the pH to come up to 7.4 to 7.6 and see what happens. Also, I will keep the filter running 24 hrs for a couple of days(I usually only run it 10hrs).
    I have a 24ft round vinyl pool with 150# sand filter, current temp. is 72F
    My experience to date with TFP methods has been great. Chemical costs have less than $80 a year, down from $250-300 and I used to run the filter 24/7 from about June 1 to Sept. 15 and now only run it 10 to 12 hrs depending on bather load. Just about always sparkling clear.
    24' round, above ground, 1hp 150# sand filter, live in the middle of corn fields, have well water
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: TF-100 test kit
    Be careful using those tabs. They don't maintain CYA they raise it. Now if you replace a lot of water on a regular basis it may not get to trouble levels.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: TF-100 test kit
    I would recommend to brush the greeen dust with your broom, and do an OCLT to make sure you dont need to slam it.
    Your FC is a little higher than recommended, (Im sure you know that though and it wont hurt anything at all). Everything looks pretty good though by your test results
    Divin Dave,
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: TF-100 test kit
    I hate to say it, but if you just bought the TF-100 then you just started using TFP methods. Four years of guessing is the antithesis of TFP. Welcome to the fold.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2014
    albany oregon
    15
    Re: TF-100 test kit
    I guess I'm confused at the statement that you have been using this tfp system yet keep tabs in the pool.
    16 by 48" 5000 gallons, AG, skimmer plus 1500 filter pump with gfci
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: TF-100 test kit
    "This year we have had a lot of rain and cool weather."
    Can you add your location to your profile as outlined here http://www.troublefreepool.com/conte...etting-started
    Usually the borate level is recommended to be around 50 ppm. http://www.troublefreepool.com/threa...ol-Why-and-How
    Solar Blanket, Well Water, Borax Added. 76
    Aug 2010
    Pekin, Illinois
    8
    Re: TF-100 test kit
    Added Borax, then decided to "Slam-it". Cl2 level this evening at 16.5ppm, scrubbed/brushed the bottom and sidewalls every day for the last 4 days. Water still very clear, just a hint of some green dust, but I want it gone, not used to having any problems at all. OCLT 2.5ppm.
    Jun 2013
    South Florida
    118
    Re: TF-100 test kit
    Quote Originally Posted by banjomarsh View Post
    Hopefully you adjusted your pH back down after adding the Borax. If your pH was in check, and you follow the SLAM levels precisely, you'll kill the algae. Overnight loss of 2.5ppm means you have something in the water, and you need to keep up the SLAM until you are done.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
