Thread: Filter plug question
    Jul 2014
    Georgetown, Ga
    6
    My intex rectangular 32' x 16' x 52" pool comes with Intex 28681EG 120V 16-Inch Krystal Clear Sand Filter Pump & Saltwater System with GFCI for Pools. I am not taking it out of the box and setting up until next spring so I will not be able to see the pump until then. My pool will be around 10ft or a little more from the GFCI plug on back of trailer. That 10ft will not have any cars or anything driving over it but will have a full size ATV about 800lbs going across it. I live in Georgia so the pool will be staying up all year round but I will take the pump inside so no chance of freezing. I am trying to figure out how to bury the cord so it is not more than a few inches down so it will not be too hard to get back up to take out for winter (our ground is hard as a rock) I was thinking electrical conduit buried just an inch or less under ground but i have a question. Does anyone know how big the GFCI plug is? I mean will it fit through a pipe opening and if so what size? Or does anyone have any ideas for the plug in so that a full size 800lb ATV riding over it will not hurt it?
    Intex 32 ft x 16 ft x 52 in Ultra Frame™ Rectangular Pool Set w/ Sand Filter Pump & Saltwater System. Pump is Intex 28681EG 120V 16-Inch Krystal Clear Sand Filter Pump & Saltwater System with GFCI for Pools. Water Capacity (90%): 14,364 Gal (54,368 L).
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Filter plug question
    Some GFCI plugs are 1 X 3 inches or so. What about bury the wire and put a board (1 X 3 or 2 X 4 over it to protect it.
