Thread: AutoPilot Pool Pilot Questions
    Aug 2008
    Niceville, FL
    2
    Wow - there's a wealth of information here. Thanks for putting this site up - it answered most of my questions, but I still have a couple.
    I have an 11,000 gal in ground pool with an AutoPilot Pool Pilot SoftTouch SWG with an SC-36 cell. The pool is gunite and about 4 years old.
    I know the chemistry is completely whacked - I'm going to work on getting the water balanced and try to train my family to do some basic tests and maintenance while I'm not at home so it doesn't go out of range again. The reason I got into this mess was that I didn't know about the importance of stabilizer (perhaps I forgot, but I don't recall being briefed on it by the pool builder). After 4 years of tropical storms, backwashing the filter and kids, my CYA reading is non-existent (I do my own testing). Fortunately, I know what I need to do now, to get the chemistry corrected (thanks to this site).
    As I said, I have an SC-36 cell. I had to replace it once (after 2 years) and I'm going to have to replace it again - cleaning it (I had significant white buildup on the plates) repeatedly has rendered the plates almost wafer-thin. When I do replace it (after balancing the chemistry), can I replace it with an SC-48, or is that overkill? Will the SoftTouch unit support an SC-48 and are there any jumper settings that I have to change when I change the cell?
    Also, I've read a lot about the Pool Pilot Digital units and they sound like the cat's pajamas. Is it possible to simply swap the SoftTouch unit with a Digital unit, or are there changes that have to be made in the wiring, setup, etc.?
    Again - thanks for this site!
    JoshU's Avatar
    New Orleans, LA
    543
    Re: AutoPilot Pool Pilot Questions
    Yes, you can always safely up size your cell with an AutoPilot systems. There are ways (i.e. "Cell Power Settings") that you can adjust to curb the production levels of higher producing cells. You will of course see better performance and a longer cell life with a larger cell.
    Yes, the SoftTouch will support the SC-48 cell. There are no jumper settings that need to be changed. You will just need to change the setting on the system itself and "let the system know" it is now running a different size cell.
    This is also possible. All of your plumbing will stay the same. You would be able to use the same cell and tri-sensor cords also. However the DIG-220 power supply will include new cords. So you'll just have some spares. Other than that you'll just need to disconnect the power going to your SoftTouch and wire in the DIG-220.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Aug 2008
    Niceville, FL
    2
    How do I "let the system know"? I haven't seen anything in my manual about what needs to be done...
    Thanks!
    Ft Lauderdale, Florida
    1,455
    The Soft Touch does not have a program setting to match the cell. It will operate properly, regardless of the cell that's installed. The rest of Josh's response is correct.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
