Thread: Leaking Sand Tank
    Leaking Sand Tank
    Does anyone have any experience with repairing a plastic sand filter tank? My tank has a seam that runs from top to bottom and has about a 1/16 inch leak just below flange for the valve. I assume its ABS plastic. Is there a plastic cement that will hold under pressure?
    24 X 52Ěround, Vinyl AGP, 150 lb Sand 1.5 hp filter
    30,421
    Re: Leaking Sand Tank
    How does the valve attach? Is it like a large hose clamp?
    Yes, its a black plastic collar that holds the valve to the tank. the leak in the seam on the curved part of the tank 1/2 inch down from where the valve meets the tank. I just removed the valve for better access.
    30,421
    That may be tough finding a permanent fix because that area constantly flexes as the filter is pressurized or not.
    The safest is simply to buy a new filter body and be done with it. Short of that, you can try using some epoxy and it may work fine but that is not a place I would want the filter to blow open.
    I think I would replace it.
