Thread: DEL Ozone Eclipse
    Aug 2014
    Phoenix, AZ
    3
    DEL Ozone Eclipse
    Just wondering if anyone had a long-term experience with this system? Do you use combined ozone, chlorine or just ozone. How is it working out.
    Thanks
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: DEL Ozone Eclipse
    Welcome to TFP!
    Ozone is not approved by the EPA as a primary sanitiser and thus should not be used alone.
    The use of ozone in combination with chlorine is not generally recommended in a residential outdoor pool as our experience shows that the combination increases the use of chlorine as compared to chlorine alone.
    It would be good if you can add details about your pool as described in this post so that we can help you better.
    Aug 2014
    Phoenix, AZ
    3
    My pool is 40' x 18', play pool, roughly 40K gal. We've been using salt water until few weeks ago InteliChlor died. Now considering using chlorine tablets and ozone.
    May 2014
    584
    We do not recommend the long-term use of chlorine tablets as tablets contain both cyanuric acid (CYA) and chlorine. The chlorine is used up but the CYA accumulates. The problem with this is that as CYA levels increase, you would also need to increase the chlorine proportionally in order to prevent algae.
    Please have a look at the following articles -
