Results 1 to 7 of 7
Thread: TF-100 test kit question
    May 2014
    Kent, WA
    12
    I inherited a TF-100 test kit with an above ground pool. It does not have the scoop in it for the chlorine drop test. I know I can buy one but for now can anyone give me an estimate of how much R-870 powder to use.
    8.7K 12'x24'x54" AG install 8/2014 Hayward S144T sand Hayward 1 spd MaxFlo 1 hp pump TF Test Kit
    38,371
    Re: TF-100 test kit question
    It does not take much. You could use the little clip on a pen cap. As long as the water turns a nice pink and there might be a few crystals undissolved, it should be plenty. You can not use too much, but too little can be problematic.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    the spoon is about 3/16 inch diameter so you have an idea it is only a small amount
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    May 2014
    Kent, WA
    12
    Thanks to both--this gives me a good idea of what I need.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It's just a pinch. Literally, like a pinch of salt. Hardly any at all.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Oct 2013
    Chapin, SC
    1,141
    I'd be willing to bet Dave will send you all the scoops you need for $.15 a pop. I'd also bet they can go first class mail in a regular sized envelope for the cost of a stamp?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Kent, WA
    12
    Thanks for the responses. I reordered the reagents and got a spoon with them so I am now set.
