Thread: Help With My Valves New Pool Owner
    Aug 2014
    Coral Springs, FL
    7
    I'm a new pool owner and was trying to make an adjustment to my pool cleaner, upon doing so I lost prime in my pump. I was able to get it back following some instructions but now I'm not sure if my values are in the correct place. My memory says they are and everything seems to be functioning normally but wanted a double check. Please Help!!!
    9,500 Gallons
    IG
    Jacuzzi Cartridge Filter
    Hayward Navigator Pro Cleaner
    38,388
    Re: Help With My Valves New Pool Owner
    Welcome to TFP!!!
    There is not "right place" for the valves to be ... depends on what you are trying to accomplish. Can you label what each of the pipes are? Are those in the picture the suction lines?
    Right now you have all 3 of the lines open, which may not be ideal.
    Aug 2014
    Coral Springs, FL
    7
    Thanks. Here is a wider shot. Those are all suction I believe. I'm going to assume one is the pool cleaner, one the bottom drain, and one the skimmer but I could be wrong. I noticed when I adjust them the pool cleaner will stop which I know is not a good thing and the strainer box will either have some air bubbles coming in or none.
    9,500 Gallons
    IG
    Aug 2014
    Coral Springs, FL
    7
    Thanks. Those are all suction. I'm going to assume one is the pool cleaner, one the bottom drain, and one the skimmer but I could be wrong. I noticed when I adjust them the pool cleaner will stop which I know is not a good thing and the strainer box will either have some air bubbles coming in or none. Can you give me an idea of what to look for in what should be accomplished.
    9,500 Gallons
    IG
    38,388
    If you are not running the cleaner, then you would want more flow to the skimmer. And not much flow ever needs to be pulled from the floor.
    I would suggest you ID which pipe is plumbed to what and label them.
