Results 1 to 11 of 11
Thread: Buyer beware on bleach 8/15/2014
    went to Walmart to buy up on bleach Great Value. That's fine, BUT I noticed a "SPLASHLESS" type there also in Clorox. Sodium Hyperchlorite percent not listed on Splashless. Checked Clorox MSDS and it said 1-5%. Someone want to follow this making sure I'm correct? Thanks Dave G.
    38,415
    Re: Buyer beware on bleach 8/15/2014
    You should not use splashless anyway, regardless of the strength.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Do not use Splashless in your pool! If you bought it from Wal-Mart, you can return it or exchange it for their Great Value plain bleach. I've made that mistake when I was in a hurry and I had no problems returning it.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    What is splashless anyway, I never noticed it before
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Splashless has surfactants added to it to make it more viscous and splash... less. These surfactants will also cause foaming and bubbling in your pool with circulation, turbulence and aeration.
    Isolated Spa - 345 Gallons
    Thanks to all. I wanted anyone to realize what I did that there is this other bleach out there and evidently its marked not for disinfecting
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    FYI, In addition, there is also outdoor bleach and scented bleach, neither of those should used for pools.
    Karen
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    What about bleaches that are labeled "Germicidal?" Is that a marketing term or actually something different than "regular" bleach?
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by fatboy1271 View Post
    All bleach is somewhat "germicidal" by nature. It kills germs. The wife uses the splashless stuff in the clothes washer. Good for there, but not the pool, as already mentioned.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    I had a relative(mother in law) bring her cleaning stuff to my house . She left a gallon of spashless clorox brand in my basement. Not sure how long it was there , but the plastic jug started to leak from the bottom of the original plastic jug. Whats in the spashless that would make a plastic jug fall apart?
    25,000 gallon Inground vinyl liner , Sand filter. Southern PA USA
    Mar 2007
    San Rafael, CA USA
    12,082
    There's nothing in the splashless that should have caused a leak. That was probably some defect already there, perhaps at a seam in the plastic damaged during shipment/handling.
