Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Might as well close the pool!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    The water temperature is 65 degrees, (thanks to a ow of 46 last night, similar tonight, too.) with no temps forecasted above 80 for at least a week here in west-central PA. Looks like there won't be much swimming around here. I will just run the pump, add a little bleach, and call it a year until I can cover it for the winter.
    Apr 2013
    Battle Creek, MI
    298
    Re: Might as well close the pool!
    Heater not an option?
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    38,319
    Your water is not cold enough yet to fully close the pool. Although maybe you know that ...
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I know, hence the adding a little bleach and running the pump a little bit. I am just a bit disgusted that it is mid-August and the water is below 70 degrees. It would take a week of 80+ temps to get it warm enough to enjoy. With lows in the 40's, it takes too long for the heat loss to recover. Keeping the pool covered isn't doing any good. Same thing happened last year. For some reason August isn't as hot as it used to be....,
    Jun 2014
    Toronto, ON, Canada
    98
    Sorry I don't. Could you elaborate?
    12' Intex Metal Frame Pool, 1500 gallons, Intex 2800gph Sand filter/pump, AquaPro PRO1100 HP, K-2006 Test Kit
    38,319
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by PAGirl View Post
    Do you have little ones who want to swim? It's funny because the first week I had ours open in May, my kids were willing to brave just about anything to get in. Now that I have not one but two separate heat sources, they won't even stick a toe in unless it's above 82!
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    PAGirl, I wish I could trade some of our heat for your coolness. Our water has been hitting 96. I had to take out our sprinkler/cooler because the Polaris kept hanging up on it. I know you all had a bad winter. How long was your swim season this year?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    PAGirl. I know what you mean. Being in central PA also I just get pi$$ed watching the weather report. I am still under construction, mostly just the deck now but it has been swimmable with a ladder over the side since mid July. I can probably count how many times on one had we have been in it. It's like the year I bought a snow blower, it snowed twice.
    I haven't removed the cover in over a week. Been just dropping in about two cups a day, and walking away. I will say the water hasn't gone below 80 since I filled it up. When I did my bleach dump, it said 81. I didn't think I would need a heater with the clear solar cover, when it was warm it hit 91 in a couple days. Now I am thinking I might look into it for next year.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Jun 2012
    Hudson Ohio
    47
    Heaters are definately worth it..My Husband heated up the pool enought to swim on Easter and hopefully we can swim till the end of September:http://www.troublefreepool.com/image...y_swimming.gif
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Wow, that is impressive. Heck I am just hoping to get in it at all.. haha. I will look into it for sure. I am moving my equipment pad after I close it, I'll be sure to keep space.
    Orlando, FL
    690
    Quote Originally Posted by CeeElGee View Post
    Pre hot tub, the girls would swim in any temp. Post hot tub, they won't get in unless it's at least 82. At 82 they swim for maybe five minutes. My how a little warm water can change people. Lol
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    With a temp of 45 degrees right now, I wouldnt be surprised if the water was near 60.
    Jul 2013
    Lelystad, The Netherlands
    60
    Same in The Netherlands
    We have a big party today So I have been heating up for 3 days now, but I loose at least 1 degree celcius overnight. I guess today will be the last swim of this season (perhaps a newyeasrs dive at the end of the year).
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    I'm in Michigan, PAgirl, and know what you mean about feeling a little robbed.
    I said to H last night I'd like at least one NIGHT hot enough to enjoy a moonlight swim with the torches aglow.
    We DO have a heater, and have been heating it, and I still swim most mornings after working out, even though the air temps are cold. As expensive as it is to heat, I will suggest that you might get more enjoyment from your pool if you consider heating it. You just have to kind of decide if its worth it to you. Eg. Our gas BILs are roughly equal to a cold winter month with Therese kinds of temps, but I guess I feel the enjoyment, however fleeting, of that early morning swim is worth it.
    I don't know about PA, but next week there's supposed to be some warming going on here
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    Agree with original poster. I am in central NY and this week has been rain rain rain and the water cooled off to 70. Might as well close it, can't wait for Labor Day, to shut it down...
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    I'm in western Pa. and we have been in the same boat with rotten weather and little swimming. Several nights have gotten down into the 40's. I do have a heater, but I hate to run it for hours to warm the water up and by the time the water is warm the sun is gone and more than likely raining. My crew won't get unless it is a nice sunny day and water around 86. Maybe next year will be better!
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    It has been a very cold August and I've only been in the pool twice this month because the very cold nights. Each time I swam this month, I had to turn on the heater because my pool was in the upper 70s, brrr!
    I am really bummed because I spent a fortune removing trees in July to get more sunlight, but these cold nights and cool days have been a bummer.
    I think I'll put my safety cover on my pool soon to keep the leaves out and wait a few weeks longer before I close the pool.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Perhaps I shouldn't mention that it's close to 100F around here and the pool is a nice 83.
  20. Back To Top    #20
    Jul 2014
    Peoria, IL
    389
    In central Illinois it has been cold and overcast as well. Definitely not a good pool summer. I usually heat at beginning of year and turn off heater and have to install fountain by July 4th to cool off. Not this year. My rule of close when the kids go back to school may happen this weekend if the weather does not warm up like it is supposed to.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
