Results 1 to 11 of 11
Thread: New to SLAM- am I doing it right?
    Jun 2013
    Dunwoody, GA
    74
    This week I noticed some green spots on areas of the pool wall, so I figured I needed to SLAM to get it gone. I had slacked due to work travel, heavy rain, no other problems all summer, I know….---other than some algae spots the pool is clear and looks great. I have been brushing the pool walls and vacuuming last 2 days
    Last night I added around 220 oz of 8.25% bleach I got from Home Depot, based on my CYA of 38, should have gotten me to around FC 15
    Test this morning
    PH- 8.2--8.4, up from 7.5 last evening (I believe this is due to SLAM) Should I reduce this today?
    FC- 14 - close to my target
    CC .5
    TC 14.5
    CH 275
    TA 90
    CYA 38 (I don't adjust this until I have pass the OCLT correct?)
    In addition I have been running my SWG on 100%
    So I am looking for FC loss overnight tonight (Friday)- questions on this
    Do I need to shut off my SWG for accurate comparison? Edit- I will shut it off
    Should I run the pool overnight? Edit- I will run it overnight
    Do I sample tonight for comparison tomorrow morning? I have to be gone this evening from 5PM- 10PM or so- best sample at 10PM? Edit - I will do the test tonight around 10 and again in the AM around 7
    Tomorrow morning I am looking for no more than 1 of FC, < 0.5 in CC, correct?
    Thanks in advance
    FYI I got the TF-100 test kit over the summer, this is what I have been using for testing.
    Tallman Monterey (fiberglass), 16'x33', 11500 gallons, 480 sq/ft, Depth: 3' - 5' 6", Salt Water, TF-100, Pentair pump, sand filter, Easy Touch Control System, SWG
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: New to SLAM- am I doing it right?
    Yes, turn off the SWG, run the pump, and 10:00 should be fine for night test, as long as you test in the a.m. before the sun is up.
    Jun 2013
    Dunwoody, GA
    74
    Quote Originally Posted by PAGirl View Post
    Thank you, yes I just read about shutting off the SWG, will do that this afternoon. I all have to test the pool around 7AM tomorrow as I will be gone from then until after noon or so
    Jun 2013
    Dunwoody, GA
    74
    Also my salt is currently at 2900 PPM, I would like to add a bag, any issue doing this during SLAM?
    38,252
    Add the salt whenever you like. Make sure the SWG is off for a day.
    Jun 2013
    Dunwoody, GA
    74
    Make sure it is off a day for the OLCT?
    If so, I can go shut it off now and do the test tomorrow night? Will still do it tonight for a baseline
    38,252
    No. The SWG should be off for a day after you add any salt. You should still run the pump.
    Jun 2013
    Dunwoody, GA
    74
    Ok, I did not know to shut off the SWG after adding salt.
    I checked again, FC is now 16, CC .5- TC 16.5 so its up from this morning
    I have shut off the SWG and added the salt
    Also concerning turning off SWG, I am not sure how to turn it off, I just changed it to 0% output, is that OK?
    Aug 2010
    Dallas, TX
    4,052
    That's fine. It should be off for the OCLT too by the way.
    Jun 2013
    Dunwoody, GA
    74
    Just tested it again, down to FC 13 and CC .5
    I am not sure if this matters, it doesn't matter until I get a reading tonight and then again in the morning right?
    I wonder if this is normal depletion for a sunny 84 day in Atlanta
    Jun 2013
    Dunwoody, GA
    74
    Friday night I was FC 11 and CC .5, Saturday 7am was FC 10 and CC .5 so I think I am done with algae
    Today I was at FC 4 but I hadn't turned SWG back on, is now
    CYA is 30 so adding stabilizer 16 oz at a time via sock, do I need to run pump 24 hrs.
    Also added 96oz bleach to raise FC
