Thread: Mustard aleagy
    May 2014
    Plainsboro, nj
    28
    Mustard aleagy
    Hi
    I see some green stuff at the bottum of the pool and some on the side wall. it goes away when we brush and comes back on the next day.
    pool numbers are FC 8, CC 1 PH 7.2. I had similar problem last year at the same time . that time I used some aleagy controll from leslie pool. and it worked. any recommendations?
    thanks
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,509
    Re: Mustard aleagy
    Welcome!
    How do you get your FC? Tablets, bleach? It would also be of great help to post a full set of results to include CYA.
    My guess is that your CYA level is high and the FC of 8 is not high enough to stop algae growth.
    I suggest you read this link to learn about the how and whys of taking care of your pool using your own test kit.
    http://www.troublefreepool.com/conte...ater-chemistry
    You can find the link to the good test kits in my siggy below. If you add your pool info. it would be helpful also. Here is the link on how to do it.
    http://www.troublefreepool.com/conte...efore-you-post
    You can take control of your pool using TFP. It will be easier and cheaper if you do some reading and testing.
    Kim
    May 2014
    Plainsboro, nj
    28
    Re: Mustard aleagy
    I think i got your point. I use Laundry bleach for chlorine but at the same time i use tablets once in a week . I read on this site that tablets could increase CYA Level. my CYA is 40-50. I use testing kit recommended by this site. I never go to pool shop to test the water. what is the recommendation at this time? should i Slam the pool?
    Jul 2014
    Bastrop, Louisiana
    199
    Re: Mustard aleagy
    Do a complete set of tests from your test kit as Kimkats has suggested and post them here so we can see what the water chemistry is.
    Edit:
    Sorry, missed the last post where it gave the CYA
    Last edited by one_knight4u; 08-15-2014 at 07:31 AM. Reason: missed op's last post
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    Jul 2012
    Tallahassee, FL
    30,509
    Re: Mustard aleagy
    The green alone says a SLAM is needed.
    Stock up on chlorine/bleach and get started.
    Don't forget to brush every thing. Take the stairs out and look inside any lights you might have.
    Good luck!
    Kim
