Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Accidentally added to much bleach to pool
    I just shocked my pool to a chlorine level to get rid of mustard algae. I used 7.25 bottles of bleach. My wife noticed on the bottles of bleach that it was a higher concentrate of bleach. Kind of like the new laundry detergents that use less detergent for same wash loads. Any I might have added 3 jugs to much.
    Should I worry about anything?
    Eddie
    30 foot round pool. 4 feet deep.
    21,200 gallons
    AG
    Sand filter
    Taylor FAS-DPD Testing kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Re: Accidentally added to much bleach to pool
    Not at this point. Test the water in the morning and see what the FC level is. It should drop over the next couple of days.
    Support the site
    I forgot to put down the chlorine shock level. It was supposed to be 23.8. So Obviously it's going to be a lot higher.
    Eddie
    21,200 gallons
    AG
    Sand filter
    38,537
    Why such an odd shock level? That is not what Pool School or PoolMath says.
    I have mustard algae in the pool. I found a chart online that tells you the shock level to kill the mustard algae. Typical shock level from TFP chart doesn't get high enough to kill it.
    21,200 gallons
    AG
    Sand filter
    May 2014
    Franklin, NC
    9,205
    chem geeks extended chart shows 23.8 for 40 CYA
    Support the site
    Oct 2013
    Chapin, SC
    1,141
    You haven't mentioned how you get your test results--what ARE the test results? Most everyone here using regular bleach instead of liquid chlorine is using 8.25% bleach. I'm assuming that's what your'e talking about. You don't mention where you get your bleach from either. Hope it is a bigbox such as Walmart or target whose turnover is pretty fast so the bleach doesn't get old and lose it's strength like you might find in a dollar store.
    Shock level for mustard is 29. So if you added what I suggested you might have that would increase your FC by 28ppm. You might be in decent shape if not needing to add more.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,537
    Did you read the mustard algae article in Pool School? PoolMath displays the mustard shock level as well.
    Yes I did. That's where I found the 23.8 shock level. I meant to do that level but like I said I didn't realize the bleach was different. And I bought the bleach from Walmart. I just checked the pool and there isn't any more algae. Heck there's probably nothing living in the pool now.
    21,200 gallons
    AG
    Sand filter
    Oct 2013
    Chapin, SC
    1,141
    Going back to July 24th in you other thread, your pool store cya number was 142? I don't see any more current numbers. Am I missing something? At 142, the mustard shock level is 75?
    Quote Originally Posted by timerguy View Post
    I drained my pool last week to fix the cya. Cya is now 40.
    21,200 gallons
    AG
    Sand filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Did you do a full SLAM, or just a short burst of high chlorine level? Otherwise, the mustard algae will be back, most likely.
    Quote Originally Posted by PAGirl View Post
    Slamming. Suppose to hit it at shock level a couple of times. Since chlorine is accidents high, it's still above shock level. Cya and ph was good.
    21,200 gallons
    AG
    Sand filter
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    You are supposed to hold the SLAM level until you meet all three criteria to end:
    Less than 1 CC
    The OCLT
    And clear water.
    Then you take it to mustard algae level for a day or two. After that, you let the levels fall to the normal maintenance range for your CYA level. Otherwise, it will come back.
    You never answered how you were getting your test results. ??
    Actually, if you pass the three criteria for ending the SLAM, you don't need to raise to mustard algae level.
    It's only when the SLAM isn't working as effectively as it should that you want to try the mustard algae chlorine level.
    Or, if the pool is so cloudy that you can't see the bottom, that means nobody should be allowed in the pool anyway, and you can start your SLAM by targeting the mustard algae level to speed things along. Standard shock level (as related to CYA level) is safe to swim in, mustard algae shock level is not.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    I have a test kit plus I get my water tested by the pool place weekly.
    21,200 gallons
    AG
    Sand filter
    38,537
    What test kit?
    Pool store testing is horrendous and not worth the fuel to drive there.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    From pool school:
    To permanently get rid of mustard algae, you first SLAM the pool normally, following the directions in How To SLAM Your Pool. Once you have completed SLAMing your pool in the standard way, raise the FC level up to the extra high mustard algae shock level for 24 hours. Use PoolMath, or see the Yel/MstrdShock column in the chart in this post, to find your mustard algae shock level.
    http://www.troublefreepool.com/conte...-mustard-algae
    I've shocked the pool at the mustard shock level. However I tested it today which is about day 3 after the initial shock and it has dropped from 23.8 to around 10 according to my test kit. The pool store is about 5 mins. away from my house so I might try them tomorrow. I guess I need to invest in a better test kit since my mine only test chlorine level at 10 maximum. Right now my pool is crystal clear. it hasn't looked this clear in 2 years.
    Eddie
    21,200 gallons
    AG
    Sand filter
  20. Back To Top    #20
    Oct 2013
    Chapin, SC
    1,141
    It could be across the street and that won't make them any more accurate. No need to guess. You DO need one of the recommended test kits.
