Thread: Am I SLAMing correctly?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Suddenly could not keep chlorine in the pool. Started SLAM yesterday with the following readings:
    FC 1
    CYA 60
    TA 85
    CC 0.5
    Water clear
    Added bleach and brought FC to 26 at 7p yesterday. Turned off SWG and ran pool overnight. At 6am had the following:
    FC 27 (margin for error)
    CC 0.5
    Water is clear.
    Good right? Next test at 6p today. FC = 10. What's up with this? Ok, it was partly cloudy and 95 deg. But, is it possible to lose so much so quick?
    Do I need to raise it back up again and try again tonight?
    Thanks.
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    Aug 2010
    Dallas, TX
    4,052
    Re: Am I SLAMing correctly?
    Yep, with organics in the pool it is going to burn off FC very rapidly. That's why I recommend starting a SLAM on a day you can be home all day, since you might have to add bleach hourly. As you get through a day or two, it won't burn off quite so fast, so going to work is not an issue.
    38,274
    I would certainly raise it up again and do one more OCLT. Make sure you run the pump at least an hour after any bleach addition before you test at night and leave the pump running through all available pipes overnight.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Thanks. Time for round #2
