Thread: 33x18" above ground pool is now an aquarium - please help
    Aug 2014
    Cole Camp, MO
    6
    Hello.
    I recently purchased a home in Cole Camp, MO with a Lomart 18x33 above ground pool that is 52" deep and holds about 19,000 gallons. The pool seems structurally sound, but the water is the color of sewage and contains buckets of algae. It also is home to leaves, sticks, tree limbs and assorted water life, most notably tadpoles by the thousands.
    I have never owned a pool before, but I've been trying to educate myself over the last couple of weeks, so please forgive me if I don't know what I'm talking about.
    First instinct was to vacuum out the pool, but the vacuum seems to be missing the adapter that I use to connect it to the skimmer, so I have ordered one. In the meantime, I decided to siphon out the pool and start cleaning the disgusting liner. After getting it down to about 2 feet deep, it dawned on me that I didn't really want to be ankle deep in dead tadpoles, so I stopped siphoning.
    Further reading suggested that I should just bomb the pool with chlorine to kill the tadpoles so that they will float to the top and I can just scoop them out with the net. So today I'm off to buy chorine or bleach and commit tadpole genocide (unpleasant).
    So after I scoop out all the solid waste, should I just keep the 2 feet of water in there or go ahead and drain the rest? At first I thought I would drain to the bottom, but now I'm wondering if I shouldn't just fill it back up and then let the chemicals and pool filter do the rest.
    Sorry for length and thank you for your suggestions.
    Re: 33x18" above ground pool is now an aquarium - please help
    I would refill and use chemicals because the pool and liner are using the water to stay stable and in place. You could be inviting new problems if you drain it all the way. Chlorine will get it clean. You'll need to do something called SLAM, and you'll need a high-quality test kit to be able to do this. See:
    http://www.troublefreepool.com/conte...ater-chemistry
    http://www.troublefreepool.com/conte...tain-shockingl
    I agree that it is a shame if you can't re-home the tadpoles.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Aug 2014
    Cole Camp, MO
    6
    Thank you. That is very helpful.
    Is there a particular test kit that you would recommend, or a particular place from which I should buy one?
    Either the Taylor K-2006C (you can find it on Amazon) or the TF-100 which is sold by this site's owner here: http://tftestkits.net/TFTestkits-TF-100-p4.html
    See: http://www.troublefreepool.com/conte...its-comparison for a comparison of different kits with the needed tests.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    If it's truly a swamp, I would go with the TF-100 Kit with the XL option. You'll get more reagents for your $$.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
